Box Scraper King Kutter Box Blade with Hinged Rear Blade
   / King Kutter Box Blade with Hinged Rear Blade #1
Gilford
Michigan
Massey Ferguson 1533, syncro shuttle
I have a King Kutter box blade with a hinged rear blade. From time to time, I would like the rear blade to be stationary rather than hinging. Does anybody have a Kink Kutter box blade with a hinged rear blade that they have modified to be able to make the rear blade stationary when desired? If so, how did you do it?
Thank you,
Gilford
   / King Kutter Box Blade with Hinged Rear Blade #2
Cheap idea, just use a strap to keep it in place. Next you could use a few powerful magnets, you should be able to find them thin and with enough SA to fit between the plates.
Best idea would be to make and weld a set of brackets that could hold a removable arm for each side. That way you could have it adjustable to the amount of swing you wanted or remove all together when not needed.
Good luck and be sure to post what you do with Pics.
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
2017 NRG BLENDER (A55745)
2017 NRG BLENDER...
2015 FORD F-550 CAB ONLY (A55745)
2015 FORD F-550...
GRILL (A55745)
GRILL (A55745)
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
