King Kutter 5' rough cut opinons?
/ King Kutter 5' rough cut opinons? #1
GeauxLSU
Bronze Member
Atlanta burbs
Kubota L3130
Any opinions on this from owners (be used behind a Kubota L3130 HST)? Primarily for maintaining some small pastures but potentially for clearing older growth for new plots so at worst and on rare occasion, it would need to handle 1-2" saplings. Pastures are trash free. Basically, is it worth $650?? I realize that's a good bit less than other brands but I doubt it'll get a lot of use. Tractor Supply Company - ROTARY CUTTERS
Thanks in advance.
Phil
I guess the next logical question is are there any others for slightly more (+$100-$200) that are appreciably better). I'm trying to avoid a 'comma' in this purchase for something that just won't get used that much.
Thanks.
/ King Kutter 5' rough cut opinons? #3
I got a 5 ft light duty hog made by kingkutter,used it for 4 summers now,,,no problems,,cut mostly grass and weeds,very little brush though,but use it probably 50 hrs or more a year. Got a kingkutter 5 ft tiller too,its built like a tank,will outlast three small tractors I reckon,,you can always find something that costs more,and generally,they are better made,[not always],but for 100-200 dollars more,I doubt you can find a better one than kingkutter,thingy
/ King Kutter 5' rough cut opinons? #4
I also have a 5' KK rotary hog from TSC. Used it two summers now on a 26HP tractor without problems other than usual maintenance resharpening the blades. I have cut 1-2" saplings with it on a friends property.
/ King Kutter 5' rough cut opinons? #5
My dad has pulled a 5' KK behind a 7610 for the last 6 months. Through lots of seedlings, too. It is a little big for the 7610, but does very well on flat ground. The size of the 7610 doesn't challenge the KK though.
If my dad doesn't tear it up, then it must be pretty good, because he is hard on everything.
/ King Kutter 5' rough cut opinons? #6
Thanks in advance.
Phil
You were OK until you added the 1-2" trees. It will do occasional 1" trees, but feeding it 2" trees will cause damage. It's only (optimistically) rated for 1", if you read the specs.
jb
/ King Kutter 5' rough cut opinons? #7
My wife's uncle has one he bought last year, and he like's it (mows about 15 acres). The gearbox is kind of whiney though, but they said they are all like that. I have my doubts, but his is the only one I am familiar with. Has oil in gearbox, cuts good, just noisy. Anyone else have this problem? It's way noisier than his old unit was.
/ King Kutter 5' rough cut opinons? #8
I got one last year, with a slip clutch. Just used it a few hours, works great. It will cut 2" stuff fine in general, but I don't know if doing it a lot will hurt it.
Mike
/ King Kutter 5' rough cut opinons? #9
I've got a 5' KK that I pull behind my JD 855. It has done a great job for me, although I don't really use it very hard. I have 5 acres that I'm trying to clear out, and have removed a lot of briars, and smaller (1-1.5") saplings with it. The only thing I'd like to add to it is some sort of safety chain system.
/ King Kutter 5' rough cut opinons? #10
I bought a 4' KK-XB this spring. If I had it to do over again, I would probably buy something with a bit heavier metal. It gets bent up way too easy.
My dad always said, "buy the best you can afford and you will seldom be disappointed."
/ King Kutter 5' rough cut opinons? #11
The galvanized Modern cutters seem to be fine for a lil bit more in $$$. I looked at the KK but like the smoother one piece top of the Modern and the thicker metal plus being galvanized it shouldn't rust.......too bad anyways.:D
/ King Kutter 5' rough cut opinons? #12
Spending the extra $200 will get you a better paint job and some nicer welds. KK paint is pitiful on the dealers lot before the thing has ever been used. Spending $600 more will get you a better machine though.
In the under $700 category, my opinion is that the 5' KK is a great deal. Poor paint, sloppy welds but very sturdy. It is NOT i-match compatable as it comes from the dealer.
You fellas need to talk slow(er) for the newbie. :eek:
I'm assuming "Modern" is a manufacturer? I can't find anything, got a link?
What is "i-match compatible"? :confused: :eek:
/ King Kutter 5' rough cut opinons? #16
I think the KK cutters are good buys for the use you intend. Mine is a 4' and has worked well for the past 3 years. Beware, King Kutter ships all of their gear boxes dry and not every sales person knows to point that out.
MarkV
/ King Kutter 5' rough cut opinons? #17
I agree with Billy_S. Buy what you can afford and you really don't have any issues. I purchased a 6' KK Rotary Mower for use on pastures with grass, small trees (just sprouting) and blackberry brambles. After 19 hours of use, I have no complaints. The XB stuff is a little on the mild side for use in "rough" environments.
You won't want to cut 2" saplings with any cutter on a regular basis. That is hard on the drive line. Both the gear box on the mower and the PTO on the tractor. The caveat here is, if you use a slip clutch, you won't have nearly as much trouble with the PTO side. I've sheared 3 grade 2 bolts used for the drive shaft on my KK. It's about a 10 minute procedure to take apart the shield, remove the old bolt piece(s), install a new bolt and assemble it all again.
If I had it to do over, it would be about twice as much money for a JD MX6 or somehting similar. I would have a tough time using a JD for cutting in rough terrain paying that kind of price. I'm comfortable with my KK purchase. Good value for the price paid ($810 for 6').
/ King Kutter 5' rough cut opinons? #18
Northern Tool has a Howse 4' for $699 - Is the Howse a step up in quality?
/ King Kutter 5' rough cut opinons? #19
When looking I narrowed down to KK and Howse, but eventually went with Howse.
A review I wrote on this site:
http://www.tractorbynet.com/cgi-bin/reviews/reviews.pl/reviews/196
As well, Howse offers bolt-on chain guard units from the company. KK does not and aren't as easy to configure for them. The Howse is an overall better finished product than the KK but is just a hair lighter. I've hammered away at shrubbery, mesquite/oak sprouts, and the odd old wooden fence post and the thing has done just fine.......still looks like new, too.
/ King Kutter 5' rough cut opinons? #20
I've owned both the Howse and two King Kutters (well, actually one of the KKs belongs to my wife). The Howse was a superb performer for the price with very few welds and thin sheetmetal. It came apart several times and I salvaged it until it was about falling apart, then I retired it for a KK.
The KK is built better and stronger overall than the Howse, but the gearboxes are the same. They might even come from the same place. I cut so many rocks with my KK in 5 years that the gearbox seal finally gave up and the box leaked dry. I didn't catch it until it was seizing up on me. I replaced the KK gearbox with the good one on the Howse and it's still going strong.
My wife's KK is about 5 years old and we use it most of the time. I probably need to sell one of them. It's just nice to have an extra around since they take so much abuse on our land.
I think you will find either the Howse or the KK to be a great value for their price. The one advantage of the KK is any TSC can order repair parts. I guess the same thing could be said of Northern Tools and Howse, but I don't think they have quite as many stores in my area. You probably won't need many parts, but I did have to replace a blade bolt once. Those you can buy off-the-shelf at TSC.
I'd say to buy either one and don't look back. As someone else made a very good point, don't forget they are shipped with the gearbox dry. You'll need to fill them before use.
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
