Killing Oxalis
   / Killing Oxalis #1
BrentD
I've got a bit of an infestation of Oxalis in my yard, and I really really really want this stuff gone. I've tried just about everything I can think of to get rid of it, and nothing works. Roundup appears to kill it, but after a few weeks the leaves start regrowing. If you dig it up and don't get every last spec of bulb or root, the plant will come back. The clumps get to the point where they'll choke a lawnmower when you try to mow them down, and if the mower happens to pull up one of the bulbs and chop it, then it spreads even worse.
Is there anything out there that will kill this stuff short of using a torch to burn it out of the ground? (And I'm honestly not sure that would work either. Oxalis is the cockroach of the plant world. You just can't kill it.)
   / Killing Oxalis #2
Check into Bonide "Chickweed, Clover & Oxalis Killer". Seems to be pretty good stuff. Comes in both concentrate and spray. I think killing Oxalis works best in the fall. Bonide
   / Killing Oxalis #3
Try doubling the Roundup concentration. Also you can spray two weeks in a row.
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2008 TEREX USA LLC LIGHT TOWER (A50854)
2008 TEREX USA LLC...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
