Killing Grapevines
   / Killing Grapevines #1
Cdash
Milford, MI
JD 4100
Does anyone have a good idea on how to kill grapevines without killing everything else around it?
   / Killing Grapevines #2
Maybe try waiting until full green up and before fruit, and spot spray Roundup (very, very concentrated) on the leaves alone. Hopefully the roots will take it up and it will die. Sorry can't be of more help.
   / Killing Grapevines #3
This probably won't help, but I am amazed by my sheep's fondness for grape leaves! Fudge Baah ate all she could reach, then climbed a big boulder and launched herself into the top of a sapling to get more grape leaves! I had to help her get out of the sapling when her udder got caught on a branch! Poor ewe! She sure is LOUD when she's stuck! /forums/images/graemlins/shocked.gif
Pete
   / Killing Grapevines #4
cut thm with a chain saw is as about as fast as possable with least amount of calateral damage. there is also a stuff that can be brushed onto cut root ends to KILL the vine faster but I forget the name and it is expensive too. when you cut them leave them hand and cut out sections so that you can SEE them CUT. work in small square patches to avoid missing any. then re-cut following years as needed. I have 10 acres of woods that are involved with the grape vines and this was the advice I got from a forester but with the exception that he KNEW what the stuff was called /forums/images/graemlins/blush.gif
Mark M
   / Killing Grapevines #5
The best way i know is to wait till the vine is fully leaved and actively growing. Cut the vine off about 2 or 3 inches from the ground, <font color="red"> immediately </font> you have cut the plant, place neat (undiluted) Round Up soaked cotton balls or wadding on the cut.
   / Killing Grapevines #6
Some cultures incorporate grape leaves in their cooking. Mainly wrapping fillings and then roasting. [ Stuffed Grape Leaves ]
Your sheep are very knowledgeable feeders Pete.
Egon
   / Killing Grapevines #7
</font><font color="blue" class="small">( Stuffed Grape Leaves )</font>
I tried that once in a Greek restaurant; not bad, but nothing to get excited about either. /forums/images/graemlins/wink.gif
   / Killing Grapevines #8
There are a number of herbicides. One is Tordon, and another Tahoe 4e. I use the Tahoe 4e and just spray the stem with it, and it will kill woody plants. I assume it would kill the grape vine as well.
Some of these chemicals require care that they don't get into the eyes. Apparently it causes temporary blindness (which makes it hard to find your way home).
   / Killing Grapevines #9
Someone with a background in forestry told me that wild grapevines don't actually creep up into tree tops. Instead, they get started on the trees when the trees (and vine) are small, and the two grow simultaneously. If that's true, cutting the vine offf at the base should do it. I cut a bunch off about 10 yrs ago and they haven't grown back.
Incidentally, my excavator calls grapevines "widow makers". He says to resist the urge to pull them down.
Oops. It just occurred to me you may be asking about the good kind of vines. We have so many of the bad kind that I forgot about the other.
   / Killing Grapevines #10
When I lived in Dallas I grew 4 grape vines in the back yard. I had a Lebanese friend who used to come over and pick the young leaves. She used to stuff them with minced lamb, herbs and things. They were OK, nothing spectacular but definitely OK.
If the vines are small enough that you can spray all or most of the leaves without too much collateral damage, I use Round-up or Brush-B-Gone. If they are too big for that, cut them off, drill a couple of holes in the stump (depends on the diameter of the stump), cover the exposed wood and fill the holes with undiluted herbicide. I think just about any herbicide will do, straight 2-4-D is probably the cheapest. Grapes can sometimes be hard to kill because they send out long, long lateral roots. I dug grape vine roots out of my raised beds in Dallas and they were 20 to 25 feet away from the plants.
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
2011 KMC 3376 LOT IDENTIFIER 244 (A53084)
2011 KMC 3376 LOT...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
