Killing Dandelions
   / Killing Dandelions #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
This year seems to be the year of the Dandelion in my yard . I'd like to kill them off , or at least discourage their growth a bit .
I also have a good bit of white clover that I don't want to kill .
Is their a treatment for dandelions that won't affect the clover ?
Thanks, John
   / Killing Dandelions #2
Some of the Gordon's 2-4-D that Tractor Supply sells will kill the dandelions and not the clover. I know because I wanted to kill my clover as well and got the wrong stuff last year. Just read the labels and see what they kill. It is like $20 a gallon and you only mix an ounce or 2 per gallon of water.
Chris
Chris . Wow ! that was quick ! I need an excuse to go by TSC any way /forums/images/graemlins/smile.gif Thanks , John
   / Killing Dandelions #4
You could try turning a flock of chickens loose, they love dandelions. So do geese.
   / Killing Dandelions #6
Let me know if it works.
I bought some weed and feed at TSC, put it on as recommended about 1-1/2 - 2 weeks ago and don't see my dandelions or any other weed starting to wilt, but it IS making the grass grown faster /forums/images/graemlins/frown.gif
   / Killing Dandelions #7
My understanding of the killer products is they must be in contact with the leaf for a period of time. Is it possible that your application washed into the ground?
-Mike Z. /forums/images/graemlins/grin.gif
   / Killing Dandelions #8
Overall I have been disappointed in the granulated weed and feed. I felt it never killed the dandelions in our yard, and may have done some good on other broadleafs.
We put Scott's on my daughter's lawn earlier this spring and saw no difference three weeks later. Not sure if any dandelions actually got killed. Had a similar problem with spraying with liquid Weed B Gone. Don';t know what's going on there (less powerful formulation than in the past, or what).
I use Trimec successfully and expect Gordon't 2,4 D to work about as well.
   / Killing Dandelions #9
Yep, I followed directions (which is why the stuff sat in my loader for so long...waiting for the right weather), applied when the grass was wet, it sat for a full three days before we got a light sprinkle, which wasn't even enough to dissolve the "feed" granules.
I tried some other brand last year (Johnson's) and they both appear to be not working equally as well. I'm not looking for fairway, but I've seen unattended yards go entirely to weeds (been there...) and don't want the same problem here.
I was hoping the liquid stuff worked better.
   / Killing Dandelions #10
I've always had good luck with the Weed-B-Gone liquid spray. You just need to make sure that the ground is reasonably dry when you apply it, and that it won't rain for 24 hours.
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2006 NEW HOLLAND L185 SKID STEER (A52705)
2006 NEW HOLLAND...
