Kelley BH
   / Kelley BH #1
JerryT
Houston, TX
JD 4400
I can buy a new Kelley B750 for my JD4400 for about $4100 delivered to Texas. I have read a lot about Woods BH and the BH's supplied by JD & Kabota but not much about Kelley. Is this a good BH and how does it compare to Woods in quality and price. Thanks JT
   / Kelley BH #2
I have had a kelley on my tractor for about 6 years. I have put one seal kit in the boom cylinder and replaced the bucket teeth. I liked their 3pt hookup, simple but strong, and the price was right.The hoe has about 450 hrs on it.
   / Kelley BH #3
JerryT,
I know nothing abou the Kelley BH but something about the JD48. The JD 48 goes on and off the tractor pretty easily. I assume the JD 47 is similar. The posts I have read about other backhoe seem to indicate some bolts have to be messed with to get the non JD backhoes off the tractor. On the JD48 you add/remove a couple of pins, connect/disconnect hydraulic hoses and use the rocker arms to get the backhoe mounted/unmounted. Pretty simple for the most part. Certainly easier than messing with bolts.
If you are going to consider a backhoe have the dealer show you how to mount/unmount the implement.
Later...
Dan
BESTWAY AG VSK50 LOT IDENTIFIER 26 (A53084)
BESTWAY AG VSK50...
199049 (A51243)
199049 (A51243)
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2020 GEHL RT105 SKID STEER (A51246)
2020 GEHL RT105...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
