keeps throwing deck belts
/ keeps throwing deck belts #1
Ed7oh
Clarkdale GA.
Sabre 1338GS
I have a saber lawn tractor 1338 GS Model 13 horsepower Briggs and Stratton. it's starting to throw the deck belt, when the PTO arm is engaged I see the belt bouncing all Steins and the tensioner pulley bouncing up and down before it throwS the belt off. can the tensioner pulley be adjusted to tighten and stop bouncing and throwing the belt?
/ keeps throwing deck belts #2
check all pullies for slop.. spindles included. also check spindles for drag.. a high drag can throw a belt.
check for off axis bends too. IE.. un-aligned pullies. belt may show wear on one side or another from this
/ keeps throwing deck belts #3
I had a Kubota that kept throwing the fan belt. After much frustration I spoke with someone who said the internal cords could be broken. The belt looked fine, but I replaced it and the problem was fixed. It is something to try after all other options.
/ keeps throwing deck belts #4
I had an engine pully belt that kept coming off...new belt cured that
/ keeps throwing deck belts #5
Sounds like the tensioner, possibly needs a new spring. But also check the pulleys are all on the same plan, a long level works great. Hand spin each spindle and pulley looking for tight or wobble. Check for a bent deck also, cracked weld is a possibility also. Good luck.
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
1997 Dodge Ram 3500 Dually Truck, VIN # 3B7MC33D5VM559525 (A65563)
1997 Dodge Ram...
Hay Rack Wagon (A66408)
Hay Rack Wagon...
Trenching Excavator Bucket (A65640)
Trenching...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
