Wall Road
My BX2230 will not shut off. Things that had no effect: turning off ignition switch; removing key; standing up; getting off tractor with it in gear or with PTO engaged; DISCONNECTING BATTERY!!! It just keeps running. I've tried to kill the engine by pushing the loader into the ground in full dump position, but that won't even do it. Removed the ignition switch, but wires seem to be connected in non-removeable way. But as I said above, the battery ground cable is off the battery. I know diesel engines run on heat of compression, so is that what's making it keep on? I'd turn off the fuel line, but can't find where to do that. HELP!
