Keep Loosing Pins
/ Keep Loosing Pins #1
beersngars
Ohio
Kubota L3400HSD
Started to do a little brush mowing last Saturday. It was 93+ degrees and not all that much fun. Well after about 5 laps around a 4 acre field I look back and see my Woods rotary mower a little crooked. I look at the other side and the main pin that attaches to the lower arms is gone. I walk back around the field and find the pin. Next I notice the rear most threaded part of the turnbuckle adjuster is bent. This is the second time I have bent one. Is there a better set-up out there? Are there better "hair pins" or "hitch pins" to avoid the problem? Also the turnbuckle style adjusters on the lower arms are kind of weak IMHO. Any better alternatives?
/ Keep Loosing Pins #2
You can use bolts although that would be a pain.
What are you doin to your turnbuckles? I keep my 835lb BB on the back of my L2800 95% of the time and have not had any issues yet.
/ Keep Loosing Pins
Well I adjust them pretty tight so the arms don't swing over and chew into my tires. That may not be a problem on larger machines, but the L3400's are pretty narrow. There is probablt only an inch between them and the tires with the mower on.
/ Keep Loosing Pins #4
They do make lynch pins with small holes inthe ends for hairpins. i instead use keyrings thru the holes.. you get a pin that virtually can't be snatched out accidentally.. yet can be removed in a few minutes with no tools other than a thumbnail..
soundguy
/ Keep Loosing Pins #5
The L2800/3400 is the same frame tractor. I have the same turnbuckles as you do.
I basically have the same clearance issues as you do but have never had any tire rubbing problem, I just make sure that the turnbuckles are not in a bind when the 3pt is fully up.
/ Keep Loosing Pins #6
May be another plus for QA/QH, my Land Pride takes everything but PHD and I have even mounted it just to see, but to chicken to try. Pretty much set & forget.
/ Keep Loosing Pins #7
Is this what you are loseing?
I seem to be doing than same thing lately.
/ Keep Loosing Pins
Yep..those are the ones. I quit using the hair-pin type in favor of those in hopes of better results. I have no idea why they get away, but it sure is a bummer when they do. :mad:
/ Keep Loosing Pins #10
I get page display errors on thos links.
Soundguy
/ Keep Loosing Pins #11
you mean this link ? '+windowtitle+'<\/title><meta name="MSSmartTagsPreventParsing" content="TRUE"><link REL="stylesheet" type="text\/css" href="\/imperialcrown.css"><\/head><body '+bodyattribute+'><center><img src="'+imgpath+'" style="margin-bottom: 0.5em"><br>'+textdescription+'<\/center><\/body><\/html>') jkpopwin.document.close() jkpopwin.focus() } /*********************************************** * AnyLink Drop Down Menu- © Dynamic Drive (www.dynamicdrive.com) * This notice MUST stay intact for legal use * Visit http://www.dynamicdrive.com/ for full source code ***********************************************/ //Contents for menu 1 var catmenu=new Array() catmenu[0]='<a href="/pdf/WordIndex.pdf">Word Index<\/a>' catmenu[1]='<a href="/pdf/Section_A.pdf">A - Fasteners<\/a>' catmenu[2]='<a href="/pdf/Section_B.pdf">B - Hardware<\/a>' catmenu[3]='<a href="/pdf/Section_C.pdf">C - Rivets & Rivet Guns<\/a>' catmenu[4]='<a href="/pdf/Section_D.pdf">D - Vehicle Lighting<\/a>' catmenu[5]='<a href="/pdf/Section_E.pdf">E - Electrical Products<\/a>' catmenu[6]='<a href="/pdf/Section_F.pdf">F - Tubing & Tube Fittings<\/a>' catmenu[7]='<a href="/pdf/Section_G.pdf">G - Air Brake Products<\/a>' catmenu[8]='<a href="/pdf/Section_H.pdf">H - Hose & Hose Ends<\/a>' catmenu[9]='<a href="/pdf/Section_I.pdf">I - Cutting Tools<\/a>' catmenu[10]='<a href="/pdf/Section_J.pdf">J - Abrasives<\/a>' catmenu[11]='<a href="/pdf/Section_K.pdf">K - Safety Products & Welding Supplies<\/a>' catmenu[12]='<a href="/pdf/Section_L.pdf">L - Chemicals & Paints<\/a>' catmenu[13]='<a href="/pdf/Section_M.pdf">M - Shop Supplies<\/a>' catmenu[14]='<a href="/pdf/Section_N.pdf">N - Vehicle Parts & Accessories<\/a>' catmenu[15]='<a href="/pdf/Section_O.pdf">O - Assortments & Steel Equipment<\/a>' catmenu[16]='<a href="/pdf/PartNo.Index.pdf">Part Number Index<\/a>' var svcmenu=new Array() svcmenu[0]='<a href="/scantel.shtml">ScanTel® Purchasing<\/a>' svcmenu[1]='<a href="/invbalance.shtml">Inventory Balance Program<\/a>' svcmenu[2]='<a href="/inventoryreduction.shtml">Inventory Reduction Program<\/a>' svcmenu[3]='<a href="/EDIEFT.shtml">Purchasing Platform<\/a>' svcmenu[4]='<a href="/monthlyinv.shtml">Summary Billing Program<\/a>' svcmenu[5]='<a href="/CustomPurchReport.shtml">Purchasing Reports<\/a>' svcmenu[6]='<a href="/publaw101.shtml">Lot Tracking<\/a>' svcmenu[7]='<a href="/vmrs.shtml">Vehicle Maintenance Reporting Standards<\/a>' svcmenu[8]='<a href="/fieldservice.shtml">Field Service<\/a>' svcmenu[9]='<a href="/CabinetProgram.shtml">Cabinet Program<\/a>' var chtmenu=new Array() chtmenu[0]='<a href="/pdf/A_CapScrewHeadWrenchSizeChart.pdf">Cap Screw Head Wrench Size Chart<\/a>' chtmenu[1]='<a href="/pdf/A_FastenerTorqueCharts.pdf">Fastener Torque Charts<\/a>' chtmenu[2]='<a href="/pdf/A_Inch_Decimal_MillimeterConversionChart.pdf">Inch-Decimal-Milimeter Conversion Chart<\/a>' chtmenu[3]='<a href="/pdf/C_Rivet&RivetGunCombatCrossReferenceChart.pdf">Rivet & Rivet Gun Compatibility & Cross Reference Chart<\/a>' chtmenu[4]='<a href="/pdf/D_VehicleLightingBulbCrossReferenceChart.pdf">Vehicle Lighting Bulb Cross Reference Chart<\/a>' chtmenu[5]='<a href="/pdf/D_VehicleLightingCrossReferenceChart.pdf">Vehicle Lighting Cross Reference Chart <span class="hilitetxt">UPDATED<\/span><\/a>' chtmenu[6]='<a href="/pdf/F_BrassGaugeInstructionalChart.pdf">Brass Gauge Instructional Chart<\/a>' chtmenu[7]='<a href="/pdf/F_Steel&BrassFittingsSizeComparsionChart.pdf">Steel & Brass Fittings Size Comparison Chart<\/a>' chtmenu[8]='<a href="/pdf/I_DrillSizeDecimalEquivalent&TapDrillChart.pdf">Drill Size Decimal Equivalents & Tap Drill Chart<\/a>' chtmenu[9]='<a href="/pdf/I_Tap&DieChart.pdf">Tap & Die Chart<\/a>' chtmenu[10]='<a href="/pdf/CAOTC_ChemicalCrossReferenceChart.pdf">CA/OTC Chemical Compliance Cross Reference Chart <span class="hilitetxt">UPDATED<\/span><\/a>' chtmenu[11]='<a href="/pdf/M_CouplerCrossReferenceChart.pdf">Coupler Cross Reference Chart<\/a>' chtmenu[12]='<a href="/pdf/ImperialCrownWiperBladeCrossReferenceChart.pdf">Imperial Crown Wiper Blades Cross Reference Chart<\/a>' var cusmenu=new Array() cusmenu[1]='<a href="/contactus.shtml">Contact Us<\/a>' cusmenu[2]='<a href="/careers/">Career Opportunities<\/a>' cusmenu[3]='<a href="/ecomacct.shtml">Apply for an Account<\/a>' var helpmenu=new Array() helpmenu[1]='<a href="/help/help.shtml">Help Index<\/a>' helpmenu[2]='<a href="/download.shtml">Software Downloads<\/a>' helpmenu[3]='<a href="/download.shtml#scanner">Scanner Instructions<\/a>' helpmenu[4]='<a href="/warranty.shtml">Product Warranties<\/a>' helpmenu[5]='<a href="/terms.shtml">Conditions of Use<\/a>' helpmenu[6]='<a href="/sitemap.asp">Site Map<\/a>' helpmenu[7]='<a href="/contactus.shtml">Contact Us<\/a>' helpmenu[8]='<a href="/help/imgkey.shtml">Icon Key<\/a>' var menuwidth='300px' //default menu width var menubgcolor='#E6E6E6' //menu bgcolor var disappeardelay=250 //menu disappear speed onMouseout (in miliseconds) var hidemenu_onclick="yes" //hide menu when user clicks within menu? function getposOffset(what, offsettype){ var totaloffset=(offsettype=="left")? what.offsetLeft : what.offsetTop; var parentEl=what.offsetParent; while (parentEl!=null){ totaloffset=(offsettype=="left")? totaloffset+parentEl.offsetLeft : totaloffset+parentEl.offsetTop; parentEl=parentEl.offsetParent; } return totaloffset; } function positionshim(){ //display iframe shim function if (typeof shimobject!="undefined"){ if (dropmenuobj.style.visibility=="visible"){ shimobject.style.width=dropmenuobj.offsetWidth+"px" shimobject.style.height=dropmenuobj.offsetHeight+"px" shimobject.style.left=dropmenuobj.style.left shimobject.style.top=dropmenuobj.style.top } shimobject.style.display=(dropmenuobj.style.visibility=="visible")? "block" : "none" } } function hideshim(){ if (typeof shimobject!="undefined") shimobject.style.display='none' } function showhide(obj, e, visible, hidden, menuwidth){ if (ie4||ns6) dropmenuobj.style.left=dropmenuobj.style.top=-500 if (menuwidth!=""){ dropmenuobj.widthobj=dropmenuobj.style dropmenuobj.widthobj.width=menuwidth } if (e.type=="click" && obj.visibility==hidden || e.type=="mouseover") obj.visibility=visible else if (e.type=="click") { obj.visibility=hidden hideshim() } } function clearbrowseredge(obj, whichedge){ var edgeoffset=0 if (whichedge=="rightedge"){ var windowedge=ie4 && !window.opera? iecompattest().scrollLeft+iecompattest().clientWidth-15 : window.pageXOffset+window.innerWidth-15 dropmenuobj.contentmeasure=dropmenuobj.offsetWidth if (windowedge-dropmenuobj.x < dropmenuobj.contentmeasure) edgeoffset=dropmenuobj.contentmeasure-obj.offsetWidth } else{ var topedge=ie4 && !window.opera? iecompattest().scrollTop : window.pageYOffset var windowedge=ie4 && !window.opera? iecompattest().scrollTop+iecompattest().clientHeight-15 : window.pageYOffset+window.innerHeight-18 dropmenuobj.contentmeasure=dropmenuobj.offsetHeight if (windowedge-dropmenuobj.y < dropmenuobj.contentmeasure){ //move up? edgeoffset=dropmenuobj.contentmeasure+obj.offsetHeight if ((dropmenuobj.y-topedge)<dropmenuobj.contentmeasure) //up no good either? edgeoffset=dropmenuobj.y+obj.offsetHeight-topedge } } return edgeoffset } function populatemenu(what){ if (ie4||ns6) dropmenuobj.innerHTML=what.join("") } function dropdownmenu(obj, e, menucontents, menuwidth){ if (window.event) event.cancelBubble=true else if (e.stopPropagation) e.stopPropagation() clearhidemenu() dropmenuobj=document.getElementById? document.getElementById("dropmenudiv") : dropmenudiv populatemenu(menucontents) if (ie4||ns6){ showhide(dropmenuobj.style, e, "visible", "hidden", menuwidth) dropmenuobj.x=getposOffset(obj, "left") dropmenuobj.y=getposOffset(obj, "top") dropmenuobj.style.left=dropmenuobj.x-clearbrowseredge(obj, "rightedge")+"px" dropmenuobj.style.top=dropmenuobj.y-clearbrowseredge(obj, "bottomedge")+obj.offsetHeight+"px" positionshim() } return clickreturnvalue() } function clickreturnvalue(){ //if (ie4||ns6) return false //else return true return true } function contains_ns6(a, b) { while (b.parentNode) if ((b = b.parentNode) == a) return true; return false; } function dynamichide(e){ if (ie4&&!dropmenuobj.contains(e.toElement)) delayhidemenu() else if (ns6&&e.currentTarget!= e.relatedTarget&& !contains_ns6(e.currentTarget, e.relatedTarget)) delayhidemenu() } function hidemenu(e){ if (typeof dropmenuobj!="undefined"){ if (ie4||ns6) { dropmenuobj.style.visibility="hidden" hideshim() } } } function delayhidemenu(){ if (ie4||ns6) delayhide=setTimeout("hidemenu()",disappeardelay) } function clearhidemenu(){ if (typeof delayhide!="undefined") clearTimeout(delayhide) } if (hidemenu_onclick=="yes") document.onclick=hidemenu // --> </script><script language="JavaScript" type="text/javascript"> <!-- // --> </script> <script type="text/javascript" src="tabcontent.js"> /*********************************************** * Tab Content script v2.1- © Dynamic Drive DHTML code library (www.dynamicdrive.com) * This notice MUST stay intact for legal use * Visit Dynamic Drive at http://www.dynamicdrive.com/ for full source code ***********************************************/ </script> <title>73554 SNAP PIN 1/4X2-1/2 . i havent tried them but i would the next time i lose the same pins again!! :rolleyes:
/ Keep Loosing Pins #13
Very Simple Trick ... Buy some PadLocks...... Unless Houdini (sp) is in the field you should have no Problem...
Good Luck.... Just traded the bx2000 for a b2620. Hope this is funner......
Tom
/ Keep Loosing Pins #14
radioman said:
you mean this link ? :rolleyes:
Not your fault Radioman but hat was quite ridiculous.
When you post a link to someplace this website goes back and grabs something in the html for a description, that website evidently has issues.:D:D
/ Keep Loosing Pins #15
There are times that we move the pins on three point hitch attachments so they point in. That way they give more room between the attachment and the arms. There is a cover that we use with moldboard plows when attached to the three point hitch that protects the quick release pins from being opened.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2022 EZ-GO ELITE...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
John Deere 4040 Tractor (A64047)
John Deere 4040...
