Keep it simple a lesson
   / Keep it simple a lesson #1
RWolf
Central Texas
Current, Power King (antique), Soon to have JD 5103
Earlier I posted about a problem I was having with my FEL being slow and jittering. Well the final outcome is this. Had I paid more attention to detail and slowed down abit this repair might have cost me abit less. As a refresher I had taken my SCUT into a hydraulic shop for diagnosis and repair of a leaking control valve. Based on "their" recommendations I replaced the pump with the one they recommended. System worked but was v*e*r*y slow. Doing more research to confirm what I'd already suspected the pump they recommended was to small. Based on their statements "We adjusted everything to make a safe tractor" I opened the bypass valve to see if they had reduced the pressure to much. This was my mistake and I broke the bypass valve seat. Turns out they gave me a BS line I believe to cover up the fact they had me get the wrong pump. Anyway I ordered the correct pump and control valve. Bought new hoses (new pump needed larger hoses) and after installing all (new oil) FEL STILL was very slow. After more troubleshooting and with more assistance from everyone here (Thanks:D ) I finally tore the entire hydraulic system down and flushed everything. Now here's where I should have slowed down. Had I taken just a few more minutes and really looked I would have found my problem. When I flushed the tank out I found...... a piece of paper. Probably from the tanks manufacturer. BTW; I had replaced the tank initially because the old one (part of the frame) leaked badly.
I just need to remember "the more hurry I get, the farther behind I become"
Long story short now the FEL works great. Just in time to sell the tractor:rolleyes: .
   / Keep it simple a lesson #2
Glad you got 'er fixed.:) It would have been nice to avoid all the trouble and grief, but many of us have similar stories to tell at some point. Hindsight makes everything look easy.
   / Keep it simple a lesson #3
So, was the original pump good or did it really need to be replaced? That's usually my mistake, fixing stuff that wasn't broke in the first place!
jb
   / Keep it simple a lesson #4
I'm glad to here I'm notthe only one who fixes the wrong part.
   / Keep it simple a lesson #5
What's wrong with having spares? :D
Original pump was worn out. Wouldn't barely lift it's own weight (bucket). 1st replacement pump too small (get a cup of coffee before the FEL would raise completely:rolleyes: ) and second pump was correct size.
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
