3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
One thing I noticed (specifically on my tractor) is that the power steering, loader and 3pt love and need rpm to perform at their best. Is this common for all Chinese tractors or any CUT tractor for that matter? I imagine the large industrial machines already have this feature? I'd like to figure out a way to over come this (slight) design oversight so I can run my tractor within the maximum torque range (when I don't need to make more horsepower) without having to rev up the rpm so my hydraulics work better. On my tractor, the maximum torque is developed well below the maximum rpm.
Has anyone thought about having a variable multiplier to drive the hydraulic pumps, turning them at rated rpm speed regardless whether the engine is at idle or running full blast? I imagine this device as being a sort of CVT concept only operating in reverse. In other words, when the engine is at 600rpm idle, this coupler/multiplier contraption is causing the hydraulic pumps to function as though the engine is running at rated rpm. And when you increase the engine rpm the hydraulic pump continues to function the same...regarless of the engine rpm.
Now, I don't know enough about tractor hydraulics or what's available for hydraulics in general so I'm asking. Is there anything out there already like a hydraulic system supercharger or would something like an accumulator or larger pumps, more hydraulic flow any attachments or something that will do similar to what I want?
