Backhoe KB2375 Boom Valve Leaking
   / KB2375 Boom Valve Leaking #1
thepipe
It seems I'm in a similar situation as sodamo was this time last year. A few years ago my KB2375 boom began lowering itself to the ground and I suspected a slow leak at the valve. When I mounted the hoe two weeks ago, the slow leak wasn't so slow anymore! Now fluid pours out the top of the valve even when the machine is just idling. I purchased the parts manual to figure out what I needed, but can't identify which brand of valve is in it. How can I identify the valve so I can purchase the correct parts? If it matters, it is mounted on a CK30HST, all of which I bought new in 2004. Thank you.
   / KB2375 Boom Valve Leaking #2
More than likely, it is a Simco valve. There are two others Kioti used back then, I can find the names in my books if you need them, but it seems like the KB2375 bh had the Simco. If you had the schematics for each, they are very similar but do have some minor differences that you can see if you do some comparing to your valve block setup. I don't know where you live but Michigan Iron, Michigan Iron and Equipment, Kioti Tractors, Kioti Implements, Kodiak Attachments, Befco, Hound Dog Attachments, Dk Series Tractors, Central Michigan, is very good with figuring out what you have and what parts you would probably need. They ship UPS to just about anywhere and are reasonable in price. If you followed Sodamo's post, you should be able to make short work of the repair once you have the seals.
VictorW, you were right on both counts - it is the Simco valve and Michigan Iron is great. Thanks to the information in sodamo's post, I was able to fix it in half an hour once the parts arrived. I'm still reeling from sticker stock, though: a plastic washer and rubber O-ring shouldn't cost $15 plus shipping!
   / KB2375 Boom Valve Leaking #4
Congrats :) on the the fix
Agree on the $$ part
David Sent from my iPad using TractorByNet
   / KB2375 Boom Valve Leaking #5
Glad you'are up and running. I agree that is pricey. Maybe try to match the o-ring up next time. Harbor Freight has multiple size o-rings in boxes of three grades and I've seen nylon washers at Lowe's. Just a thought and maybe what I'll try if mine starts to leak. I don't believe Kioti uses that brand of valve anymore and that could bring the price up.
   / KB2375 Boom Valve Leaking #6
I don't think that cost is that high when you consider the dealer's cost to maintain stock on these small "orphan" parts.
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
20' Sea Container Mobile Hospital (A50774)
20' Sea Container...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
