KB2204 HYD PLUMBING QUESTION
   / KB2204 HYD PLUMBING QUESTION #1
1FOX
kioti lb2204
I HAVE A LB2204 JUST INSTALLED A KOYKER 120 LOADER ON IT
PLUMBED INTO THE RELEIF BLOCK USING THE PORTS IT SHOWS IN OWNERS
MANAUL, HAVE TO SWITCH FROM ONE CIRCUIT TO USE THE LOADER, AND THE OTHER TO OPERATE THE 3 POINT, CAN NOT USE BOTH AT THE SAME TIME, IS THIS NORMAL, ANY CHEAP WAY AROUND IT, ALSO ANY INFO ON ADDING POWER STEERING TO THIS UNIT
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2024 John Deere 872GP Articulated Motor Grader (A52143)
2024 John Deere...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
