Beltzington
Platinum Member
It seems most of my repair work is either on trailer lighting or lawn equipment, I have a JD LX279 Lawn Tractor with a Kawasaki 17HP engine with about 600hrs on the Hobbs, I replaced the starter 2-years ago.
Engine started and ran fine after being in the shed all winter, changed blades and parked it in the garage to use the next day. Went to start it and the starter would not turn-over the engine, just spun, here is what I have done:
- Battery charged and holds 13.1 volts, also jumped it to a running vehicle
- Pulled starter, it spins fine and throw-out engages
- Disconnected the mower deck v-belt from the engine and engine can be easily manually turned over
- I'm energizing the starter solenoid directly from the battery to eliminate any safety interlocks
Starter only spins, engine does not move, does not even sound like the flywheel is being engaged by the starter gears.
Any thoughts appreciated, do not want to replace another starter.
ps. The engine flywheel gear teeth are very slanted but they do not look excessively worn and I have no idea what they looked like when new.
