Smoody
Platinum Member
1996 Bayou 300 2WD. I have had a oil leak for about 2 years now and really wanna get it fixed. It drips on the left foot rest just under the pull crank. What could this be, just a gasket? easy fix?
TOMMYHPX4X4 said:is the oil coimin out of the pull crank houseing or is it leaking from the next part over and running down the crank ? i had a bike that the inside of the crank housing cracked i fixed it with some baker-loc stuff my dad had and it held up ok til i traded it. did you ever wash the engine down to see the point of where the oil is comin from?
the oring behind the drive hub is leaking. You'll have to remove the hub and replace the oring then reassemble.
