Karcher Pressure Washers
   / Karcher Pressure Washers #1
TonyC
Platinum Member
Monroe, Va
Kubota 1997 L3600DT 4WD with FEL
Anyone have any experience with Karcher Pressure Washers? I've had one for about 5 years now but only used it about three times a year. Now it's in the shop and they said that the pump is "shot". My inclination is to toss it out but it sure wasn't cheap. I hate to throw good money after bad so I thought I'd see if you folks have any input.
   / Karcher Pressure Washers #2
I have the "cheapie" model... about $100.00. I didn't need a high-pressure unit so I settled on the "cheapie". From the looks of the unit, I'd say it was made to be disposable, not repairable. So far, it's been dependable.
If I ever need a better unit, it will be another brand, for sure.
   / Karcher Pressure Washers #3
did you pump in some other lubricating agent after use, such as ethyene glycol. This helps the seals to stay plyable and stops the pumps from pitting etc.
   / Karcher Pressure Washers #4
I do not think much of their consumer electric model you buy at Lowe's/HDepot. We have a commercial HDS1055 hot water kerosene pressure washer at work (works on 220) since 1999 (used almost daily) and I would highly recommend it. This unit replaced another Karcher that lasted about 7 years with only a coil replacement. We would purchase another one with no hesitation (commercial unit).
   / Karcher Pressure Washers #5
We use them where I work and have not had any problems with them...
</font><font color="blue" class="small">( I do not think much of their consumer electric model you buy at Lowe's/HDepot)</font>
Yeah, the guy at the repair shop said their commercial line is light years better than their retail stuff. Either way, sometimes I feel like someone stuck a gun in my ribs and stole $400 from me. /forums/images/graemlins/mad.gif
   / Karcher Pressure Washers #7
Tony,
I've had Karcher's 5.5 HP gas run unit for a couple of years now and have had no troubles....but that doesn't mean I won't! /forums/images/graemlins/crazy.gif Sure does a nice job now though!
Kevin
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
