Cavjock22
- Joined
- Jan 28, 2017
- Messages
- 222
- Location
- Seabrook, TX
- Tractor
- Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
I have been wanting a power washer for the last several years to both use around the house and the ranch. Through a rewards program at work I ordered the 3200 power with a Honda . I began using this on Friday. on Saturday morning I went to use it again and I had oil flow out of the dipstick tube. The oil looked very black and thin. my only guess is somehow there was water getting into the crankcase. I had several projects to use it for this weekend and being I can't call about warranty till Monday I decided to suck the oil out and put fresh oil in it and see what happens. I proceeded to use it again on Saturday and it also made oil but this time it did not get black and not near as much. The wand then started leaking midday Saturday. Look to be a faulty a ring on one of the fittings. I then began having problems with the 15" surface washer attachment that I purchased of the same brand. The pump began cavitating when I tried to use the attachment. After looking into my problem I realized that the Tips we're getting plugged up with small pieces of metal. The metal was coming from the actual surface washer attachment where the threads were not cleaned out correctly. I had to remove both tips flush the pipes several times to get all of the metal threads out of the system. With approximately $500 power washer I'm very disappointed with the problems I had in the first two days of use.
I guess I'm just venting here. Things aren't just not made like they should be or like they used to be.
on a good note the 15 inch surface washer attachment is pretty awesome when it works for cleaning driveways and patios..
