Kama TS354 PTO Leak
   / Kama TS354 PTO Leak #1
AR15MIKE
Logan,Oh
Kama TS354C
Tractor has been running good, I've been bush hogging and box scraping my butt off, however there is a leak at the PTO. Does anyone know if thats an easy fix? I fixed another leak by the seat on the hydraulics, just needed some words of wisdom.
   / Kama TS354 PTO Leak #2
Contact Chip at Artrac he is a Kama dealer and should be able to help you,it is prob.just a seal that needs to be replaced
Tommy
Affordable Tractor
   / Kama TS354 PTO Leak #3
The most common mess in the PTO spline area is overflow from the hydraulic reservior vent. Generally that's caused by overfilling, incorrect hydraulic fluid, or a pretty bad air leak
//greg//
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
