Kama TS254C Fuses ratings
   / Kama TS254C Fuses ratings #1
grsr3
Bronze Member
Decided to remove Chinese fuses due to the plastic part starting to deform. Plan to leave box in place and jump gap with in-line fuses (automotive type-mini's).
Need to know the rating. Don't have an amp meter.
Thanks, Geo.
   / Kama TS254C Fuses ratings #2
Your post is a bit vague, but I gather that you distrust Chinese fuses and want to replace them with in-line fuses (probably also made in China).
An amp meter wouldn't help you. You need to read the ampere rating on each Chinese fuse and replace it with an in-line fuse of the same rating. You may find the amp ratings in the owner's manual for your machine/vehicle.
Hi Ted,
The amp ratings are not listed in the parts book or the owners manual. The plastic body of some of the fuses must have over heated at one point and show signs of melting apart. Don't know why?? Everything works ok except for intermittent disconnects at some of those faulty fuses. How do you take an amp reading across fuses without an amp meter?? When i read amps on my house wiring I close the meter jaws around the line when the load is working. That gives you the amp draw. How do you do it across the fuse??
Geo.
   / Kama TS254C Fuses ratings #4
Make sure the extra fuse wire is not wrapped around the fuse body in effect shorting the fuse out and melting the fuse body. Mine did that when I first got it.
   / Kama TS254C Fuses ratings #5
Geo,
In Googling around I find that you aren't the only one having fuse problems with a Kama. Your old fuses may have overheated if the connection from the fuse to the socket was corroded or had high resistance for some reason. High resistance causes high power dissipation (heat). For example, if you're drawing 10 amps through a connection with only 1 ohm resistance, that connection will get as hot as a 100 watt light bulb. (power = amps x amps x ohms)
It sounds like you were thinking about measuring the current flowing through the fuse and using that to guess the correct size. That might work, but if at all possible you should find the correct size fuse from a manual or maybe someone here owns the same machine and can read the amp rating from their fuses. I'm astounded that neither your owner's manual nor the parts book lists the fuse size. And I assume you can't read the fuse size from the fuse itself? See below for some information that might help.
My concern about the amp meter is this: The amp rating of fuses/breakers is not based on the current load. The size of the fuse is determined by the size of the wire that the fuse supplies. The fuse protects the wire from overheating. A given gauge wire can carry a certain amount of current (its ampacity) before it gets dangerously hot. The fuse must be at or below that rating. Of course the wire size is based on the maximum anticipated current load, so in that sense the fuse size does relate to the anticipated load.
You might find this link helpful:
CHINESE TRACTOR OWNERS CLUB FORUM
In case that link dies, here's one post from it, posted by gugliols:
I dont have a Kama but I did a search and came up with the color code and amps for chinese fuses. This may help?
http://hyyongwei.en.alibaba.com/product/50215354/51175393/fuse/Fuse.html
Color and current (A)
1) Grey: 2
2) Violet: 3
3) Pink: 4
4) Orange: 5
5) Brown: 7.5
6) Red: 10
7) Blue: 15
8) Yellow: 20
9) Clear: 25
10) Green: 30
11) Purple: 35
   / Kama TS254C Fuses ratings #6
You used a clamp on ammeter for your AC house wiring. If you have access to a clamp on DC meter (not all of them handle DC) then you simply clamp it over the line leaving the fuse. If you can't find that wire, you could remove the fuse, insert a jumper wire where the fuse was, and clamp over that jumper wire. If you have a regular volt-ohm meter, you would set the meter to DC amps, remove the fuse, and insert the probes where the fuse was, and measure the current (red probe on the battery side, black on the load side). This forces the current to run through your meter where it can be measured. Be sure your volt-ohm meter will handle the current you're expecting. Some have a 10amp maximum, for example. There are other methods like using a shunt resistor, but you probably don't want to mess with that.
   / Kama TS254C Fuses ratings #7
Geo,
A BIG FYI -
Here is a thread where I did some electrical upgrades to Rob's (3RRL) Kama 554.
The OEM wire wound fuse block was removed, then a new modern ATC type fuse block was installed in it's place. The entire thread is long but here is a link to pick up where the fuse block install was documented -
CLICK HERE then scroll down to reply # 139 and pick it up from there.
My hope is it will illustrate that with a little determination, there is nothing that can't be updated or otherwise modified on these tractors to suit your needs or desires ---
As a sample here is what was done: Please forgive me if I get carried away :rolleyes:
Rob was having some problems with a glass fuse blowing on his headlight switch. After looking at the switch I found a loose screw that was shorting out against the lower dash panel.
I am not a fan of Glass fuses in tractors so I removed the glass fuse and installed a 20 amp ATC fuse:
Since these repairs only took a short while. It was time for some serious rewiring.
I removed the OEM wire-wound fuse block to install a nice new genuine ATC fuse block:
Larry
   / Kama TS254C Fuses ratings #8
The New ATC fuse block fit PERFECTLY after drilling two new holes. I also installed two standoffs to move the new fuse block away from the metal and more forward for ease of fuse inspection and replacement.
Here it is installed ready for wires:
Larry
   / Kama TS254C Fuses ratings #9
Even though Rob's Kama is very large, getting to all the wires was a little difficult. Here I am being a "contortionist"
Rob could not bear to look at me cutting off all those wires.
Here are all the "Medical" Supplies:
And your's truly having the time of my life -
Larry
   / Kama TS254C Fuses ratings #10
Here are all the new connections on the back of the new fuse block. I had to extend the existing wires for more slack. So I added some self sealing heat shrink push connectors to short wire extensions. Since the new fuse block had 2 spare fuse positions I added some short wires so that Rob could add additional lights and or a cigarette lighter at a future date.
One of the spare circuits is Hot all the time and one is switched on & off by the main key switch.
This is a front view of the new fuse block:
Here are the fuses installed:
And this one shows the water proof fuse cover in place. It has an o-ring seal:
Larry
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
UNUSED JCT 72" VIBRATORY PLATE COMPACTOR (A51248)
UNUSED JCT 72"...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
