kama hydraulics
   / kama hydraulics #1
hoppy50680
I just got a kama ts254c with fel and bh. can someone please explain where all the hydraulic hoses go? I have some with quick disconnects and some without
   / kama hydraulics #2
Just curious, what dealer did you get your tractor from? Is it the factory loader? The factory system requires you to choose wether you want to use the loader, or the three point lift or the backhoe, they use the quick connects, and that rediculous tank on the rollbar for the FEL and a tank on the backhoe. It can be plumbed in series using the lift box tank as the only resevoir. Do not try to connect the extra tanks in series, I have sold a couple of hydraulic pumps to folks who had problems with this setup.
The KAMA is a good tractor but their loader arrangement leaves a bit to be desired, we use Koyker loaders.
   / kama hydraulics
that dont sound like a very good system, what would you do to this factory set up? It is a factory fel and bh, didnt buy it from a dealer, went through an importer.. I was told by someone once that the internal hydraulic pump should run the fel and the pump that sits over the pto shaft was for the bh.. would the internal one have enough fluid for that? Or was this guy all wet??
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
