Kama 454
   / Kama 454 #1
Ronny_Clark
Lake Charles , La.
Kama 454
Anyone have any electrical problems on a 454? I kept blowing the 30 amp fuse. I originally thought it was the gauge cluster but Today,I have disconnected all the lights at the harness in the front and back. Will look at it tommorrow then it is off to the mechanic to let him fix er up for me...So far the fuse hasnt blown but tommorrow is another day..... I would like to rewire the tractor and put some United States gauges on it.
   / Kama 454 #2
Ronny,
That panel is pretty reliable, it is the same as on the Jinma LE model and others. If the panel is bad we can replace it under warranty, but sounds like a pinched wire somewhere.
   / Kama 454
Was on a trackhoe all day long so I didnt have time to check out tractor.. Maybe tommorrow !! Will let you know chip !!
   / Kama 454 #4
I have blown my fuse on my 554 3 times now. Not sure what is causing it yet, havent looked at it real close but if i just re-wrap the fuse it lasts for a while. I wonder if the wrong wire is on my fuse holder. Anyone ever have the wrong wire wrapped? Anyone got a micrometer handy to measure the correct 30 amp wire as a reference?
   / Kama 454 #5
Ronny, I have had this problem for several months now and have still not fixed it! The electrical problem has grown to affect all instruments switches and lights. The only thing that works is the starter. Please read over the my post if there is anything that helps please let us know.
Post
   / Kama 454 #6
The wire is probably the wrong size. Mine was doing the same thing. I just wraped it twice and that stopped it!! It will still blow if there is a short. /forums/images/graemlins/tongue.gif
   / Kama 454 #7
sevencorners,
Your setup on your JInma is different. uses blade type fuses. you may have the same gage panel if you have the combined panel and not individual gages.. All of the current goes through the amp meter except the power used to turn the starter. The power to engage the solenoid however does go through the amp meter so...you have a short somewhere.
Install only the 30 amp fuse, does it blow? if not add fuses till you find the problem.
Oh one big question, has it ever worked right since assembled?
   / Kama 454 #8
Hi..I have spare cards of fuse wire for the wire wrapped fuses,,see my add under classifieds
5amp wire is .008 ,10 amp wire is .013, 15 amp wire is .020
30 amp wire is .030
MW /forums/images/graemlins/laugh.gif
   / Kama 454 #9
On another note..Yes my machine came with 10 amp wire wrapped in place of the 30 amp, it would blow every time I hit the glow plugs. Easy fix tho.
   / Kama 454 #10
aha!! I can tell you without even looking that my wire is not .030 thick. Looks like i probably have .010 at the best.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 48 (A53084)
2020 JOHN DEERE...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
