Kabuta L45
   / Kabuta L45 #1
IamVince
Kabota l45
Kubota L45
Our tractor has been sitting for awhile and after starting it ...if I try forward or reverse it dies.
Starts fine ,idles fine but try to move it dies
I googled this and thats how I found your site.....so from what I've read theres a good chance the problem is in the seat switch
   / Kabuta L45 #2
Welcome to the neighborhood.
Yes, seat switch would be my first suspect. You can take it apart and bypass to confirm. Good luck!
   / Kabuta L45
Re: Kobuta L45
Thanks Mike....so unplug the seat switch?or actually take it apart?
   / Kabuta L45 #5
It MAY be the seat switch, or it may be the seat pivot. Sometime the pivot rod under the seat comes loose on one end making the seat switch especially sensitive. It should be held in place with a cotter pin. I'd start there.
   / Kabuta L45 #6
Re: Kobuta L45
On mine, I pulled the plug from seat and shorted the two wires together in order to confirm that seat switch was the issue. Once confirmed, I resolved the actual issue.
   / Kabuta L45
It was the seat switch
As you probably noticed my spelling sucks ( kabuto)
But thanks for the help
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
