K.K. tiller. Ned a part(not sure what it is called)
   / K.K. tiller. Ned a part(not sure what it is called) #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
I bought a used tiller and it is missing the spring loaded detent pin that you push when you put the shaft on the PTO spline. It looks like it is held in by a rolled pin. What is the name of the part I need. I can't find anything.
   / K.K. tiller. Ned a part(not sure what it is called) #2
From the user manual for the standard duty King Kutter II Rotary Tiller, it looks like the part no. is 170110 and it is called a "Quick Disconnect Pin".
I believe you can download a PDF copy of the manual from the King Kutter site - King Kutter Incorporated
Nick
   / K.K. tiller. Ned a part(not sure what it is called) #3
I think you are referring to a yolk pin.
http://www.princessauto.com/all-seasons/outdoor/acreage/tractor/8087413-universal-yoke-pin-kit
   / K.K. tiller. Ned a part(not sure what it is called) #5
call KK, they have always been very helpful.
heehaw
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
(2) ALEMITE GREASE HOSE / REEL & NOZZLE W/ GAUGE (A51244)
(2) ALEMITE GREASE...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
WOLVERINE PAB-11-72W HYD QUICK ATTACH ANGLE BROOM (A51244)
WOLVERINE...
