JX85 vs JD5420
   / JX85 vs JD5420 #1
twabscs
NW Missouri
NH TC40D, CaseIH Farmall 95, 105U
Hi All,
I'm getting ready to add a utility tractor to my fleet (of 1). I have more acres now and will be using the tractor primarily for haying. I'm getting ready to pull the trigger and I'm looking at a new Case JX85 and a used (100 hours) JD 5420. The JD is $2K more has very little warranty left and the JX85 is brand new with cheaper financing and full warranty.
Both tractors have cabs and loaders with QA. The JD has the power reverser and the JX does not. The JX is somewhat of an economy tractor and the JD is more in line with the JX90U (Deluxe).
I'd like to hear the good, bad, and ugly. Right now I'm leaning toward the Deere. Both dealers seem easy to work with.
Thanks!
   / JX85 vs JD5420 #2
I would get the 5420. You get alot more tractor than the case. If you are getting a cab the cab in the JD alone is worth the extra $2k in my opinion.
   / JX85 vs JD5420 #3
Look at engine displacement for sure and rated rpm.
Do not pay much attention to lift capacity on the JX it is not correct. I have never seen a tractor lift almost as much as its weight. Deere is the way to go here in my opinion. Request a demo if you haven't already. You will see the differences there.
   / JX85 vs JD5420 #4
The power reverser in my opinion is worth the difference in price especially with the loader. Also with the power reverser you get the wet clutch. You also get the 276 cu. in. engine which is the same engine that JD uses in some of its 6000 series tractors. I think you about answered you question while you where writing it.
   / JX85 vs JD5420
Thanks for the replies so far, it was what I expected - Aren't many Case guys around here. /forums/images/graemlins/smile.gif
I went to look at the JD. The cab wasn't as "nice" as I originally thought (Maybe because it's not new?). Also, the battery was dead so I didn't get to take it for a test drive. Dealer promised to put a new battery in by tomorrow.
One issue with the JD: The QA on the 541 loader is different from that used by my TC (Skid Steer). This is a problem as I won't be able to swap my QA attachments between the machines. The dealer thought that there might be an adapter, but that won't completely solve the problem as I would need a different bucket than the one that comes with the tractor.
That JX has the 32LC Loader on it with the curved arms (and skid steer QA). The JD has the older, non-curved, non skid 541. A positive for JX85.
Although I like the JD dealer, he isn't really an "ag" dealer and doesn't have any hay equipment. I view this as a small negative.
Keep the comments coming!
   / JX85 vs JD5420
Agree - We have the bigger, non-turbo engine in the Deere versus the smaller, turbo engine in the Case. Yes, I'm leaning toward the Deere, but there is the issue of warranty. A 2 year "extended" warranty on the Deere is around $1k (has a $250 ded.)
   / JX85 vs JD5420 #7
The Deere seems to be very low hours for out of warranty.
Can you get the machine & maintenance history? Lease return or insurance claim (flood R&R) vs an estate settlement might make a difference.
Depending on what the dealer has in it there may be wiggle room to negotiate & extend warranty 6 mos? That might help balance the financial risk vs new Case cheaper money & full warranty.
A demo with each at your place may tip the scales.
A third option might be asking what the dealers have for trades coming in. May have something there that stands out.
Have fun comparing!
   / JX85 vs JD5420 #8
The JX85 is not the same, but I have a JX55 (no cab). The only complaint I have is the seat cracking very quickly.
This is a great, easy to drive tractor. My JX55 has a fully synchro shuttle, so while I do have to use the clutch to change direction, I don't have to stop.
The '55 is the first model in the JX series and I can see where I'm only scrathing the surface of the tractor's capibilities.
Mark
   / JX85 vs JD5420
The tractor is a 2002 model. The story is that an older gentleman had the tractor, he passed away, and the tractor pretty much sat in the barn. The dealer originally sold the tractor and has all records of the service, etc. The tires show very little wear.
The primary issue I have now is with the QA. I really hate to have two types of QA for my FEL implements.
   / JX85 vs JD5420 #10
Go for the Deere. The PowrReverser Tranny is worth the difference and it really extends the life of the clutch. You stated that both the Case and the Deere have cabs, check into the cost of replacing a clutch on Cab tractors. That should help you decide. Best of luck on your choice.
azzxx
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
