Just traded for an old 149
   / Just traded for an old 149 #1
Donsyl
Central Arkansas
Cub Cadet 1811 \and a cub cadet 149
I just traded an old generator for an old 149 cub.......it smokes a little, but its a good candidate for refurbishing..........the guy said that the engine didnt run and needed a rebuild. It will need a rebuild i am sure but i put a battery from my 4 wheeler in it and she started right up. She dont run rough like he said, she just smokes a little............i think i made a good trade seeing how i never use the generator anyhow..........Do you think it was a good trade?
   / Just traded for an old 149 #2
I think thats a good deal depending on your generator - a 5KW generator is $500 range new and a good 149 - running is worth about the same. IF your 149 has a mower deck and is not beat up then you have a nice unit with some simple refurb will be worth a lot more. Sounds like the engine does need some work but you can hone the cylinder and replace the rings, do a carb cleanup and head gasket yourself if your handy - will save osme $.
Have Fun- great find!
Carl
Hey Carl, thanks for the reply..i had a 4000 watt generator that is about 18 years old and have not used it in years. It had a small gas tank too, not one of those big tanks that sits on top of the unit..............it fired up 1st pull with fresh gas, after at least 5 years of sitting........but my son can use the 149 to mow when i mow with my other tractor ( cub cadet 1811) and we can have it done in half the time. I think i did ok............thanks ....Don
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
