Just took delivery on a new x595
   / Just took delivery on a new x595 #1
JohnP_MI
SE Michigan
John Deere X595
Neighbors probably thought I was strange as I drove around the yard with a stupid grin on my face. I'm still smiling. The speed suprised me as did how smooth it rode over our lawn. I'm looking forward to see how it plows our driveway and road in the winter.
Price: 13,013
62" MMM
3 pt. Cat 1 hitch
Front mounted 54" blade
HDAP Tires
   / Just took delivery on a new x595 #2
Hello JohnP!
Good for you! I took delivery of a X595 about 6 weeks ago. I have been very happy with it.
54in deck, and no blade /forums/images/graemlins/frown.gif
Saving my $ for a Johnny Bucket,
Your price looks quite reasonable with the extras!
Post pictures if you have a chance!
   / Just took delivery on a new x595 #3
John,
You will be amazed at what the 595 will do in the snow. I used mine to push snow from steep driveways in my area in winter without chains. Four wheel drive and go. One suggestion: I would suggest putting liquid ballast in your rear tires. It smoothes the ride and offsets the weight of the front blade a bit. The tractor does not NEED it, but it makes things go smoother. I like the Rimguard due to its weight and biodegradability, but anti freeze and washer fluid work well, they just are not as heavy.
John M
   / Just took delivery on a new x595 #4
Congratulations! /forums/images/graemlins/smile.gif
I did notice the owners manual recommended adding rear weights when operating without the mower deck attached. I hadn't considered filling the tires. What's the procedure to do this - or is it something the dealer would have to do? Also, has anyone priced the quick-tach (sp?) weights?
Thanks,
-John
   / Just took delivery on a new x595 #6
I think the rear quick detact wt bracket is around $160, weights are ~ $40/ea.
You will need the quick detact brackets (that remain on the tractor), ~$80.
Of course the advantage is you can remove the wts when not needed, filling tires means they will stay filled until you drain them.
   / Just took delivery on a new x595 #7
John,
I had my dealer do the ballasting in the rear tires, but one can do it, I just never have. The dealer did mine for free since I bought the tractor there, so you may want to check that out. I understand the thoughts about weights on the back quick tatch bracket, but wheel mounted weight is better I think than is ballasted frame weight. The brackets are easy to install, but for the money buy one of the Quick tach weight boxes and fill it with your choice of ballast, especially if you do not want to pay for the weights. Sand, cast iron weight plates, etc. are all reasonable. My opinion is to still have wheel mounted weight in snow, it really makes those HDAP tires go well. JD makes a 72# starter weight that is cast iron and will add 144# to the rear wheels. It also blocks the valve stem and scratches the rim when it comes on and goes off. I did not like that. They also make a 50# plastic weight, which does OK, but 100# of weight is not that much. I would suggest filling the tires and adding the 50# plastic weights in winter. That will give you 200# + of wheel mounted ballast and not get the bracket. I found that my tractor did not compress the ground any more with the ballast than without, say for mowing. Keep in mind these tires have very low ground compaction anyway and that extra weight, if anything made mowing rough terrain smoother and hill negotiation easier without tearing up grass. All ideas here are great, I just found this to be the most effective for me, so wanted to share.
John M
John,
Thanks for the information. I'll stop by the dealer tonight to see if they'll fill the rear tires when they install the blade. I hadn't considered the wheel-mounted weight option. I wonder if sandwiching a plastic sheet between the metal weight and the wheel would keep the weight from scratching the wheel.
-John
So, the tractor was delivered almost a week ago. So far its been used to mow (twice) and move some carts of pea gravel around. Here are my observations - these might seem picky and obvious, but to someone considering this tractor they might be useful.
1) The 62C deck does an extremely nice job mowing. Compared to the 42C deck on my previous tractor, the 62C stands the grass up much better and the cut is very even. My neighbor has a Simplicity Broadmore w/ lawn rollers and the 62C creates a superior finish. I suppose a photo comparison is in order - I'll work on it.
2) The steering wheel drifts slightly. This isn't really noticeable while driving, but when I occasionally look down I notice the "John Deere" spoke on the wheel shifts locations. For instance, when travelling straight during one pass the "Deere" spoke will be at the 3 O'clock position, after reversing directions the "Deere" spoke might be at the 12 O'clock position. The drift is most noticeable after steering lock to lock. I attribute this behavior to the open-loop hydraulic piston moving the wheels.
3) The coolant level in the reservoir dropped approximately 2 cups after 3.5 hours of mowing. Dealer thought there might have been a bubble in the system when it was filled. So I topped it off and will be watching the coolant level closely the next few mowings. I was paying close attention to the temperature guage and the needle never came close to the red zone so I don't believe the loss was due to boil-off - unless the guage is bad, but then again there was no coolant smell or spray under the hood.
4) With off-road diesel fuel costing about $1.30/gal where I live and the reduced fuel consumption of the engine, I'm saving about 50% in fuel costs compared to my old JD LX 266. I also fully expect the engine/tractor to outlive me.
   / Just took delivery on a new x595 #10
My steering drifts too on my X595.
My temp gauge only goes about 1/4 the way into the green zone even on the hottest of days. I don't think it is an issue.
no coolant issues, seems to stay right on in the reservoir tank,
Watch your fuel gauge! On my it seems to stick at Full until about 1/2 tank, then it begins to register normally. JD claims it is a design "feature". (funny shaped tank I think!)
Sips diesel, I plan to give my X595 to my son in my "will". ha!
That Yanmar engine is the smoothest engine I've ever own!
71057 (A49346)
71057 (A49346)
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2021 Snake River 14K Dump Trailer (A49461)
2021 Snake River...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
