Just to make sure I searched correclty
   / Just to make sure I searched correclty #1
keltonkrew
Riverside, Tx (Lake Livingston)
2006 MF GC2300 - 2005 CC-2042 - Honda Harmony self propelled
After doing searches on filters, oil, etc. for my 2005 CC 2042 Here's what I have determined. Please verify if this is correct.
oil filter Carquest 85516 (2x longer than oem)
Oil - Mobil 1 10wx30
Trans filter Carquest 85410
CC fluid for the rear.
I've read to change the oil after the first 5 hours and the trans filter after the first 5 or 10 hours (have to read my manual again). Trans filter again at 50 hours, then every 100 hours after that.
I hated to post this question again, but there was so much information in multiple posts, just want to be sure I understood correctly.
   / Just to make sure I searched correclty #2
Them's the ones! I just picked up a couple more 85516's for my pre winter oil changes /forums/images/graemlins/frown.gif. One for my ford windstar, one for my 2544 /forums/images/graemlins/grin.gif M1 is awesome, but I'm not sure it's needed unless you mow commercially (tons of hours), or use the tractor in extreme cold. Any quality 10w-30 if fine for the residential user. You wont gain anything by using M1 in this application.(just my opinion!!)
G/luck
Joel
   / Just to make sure I searched correclty #3
When looking for a cross ref to a filter I usually take a look at either the Wix or Baldwin web sites. Put in the original number and it will x-ref. Like the Baldwin site as it give a good tech description of the filter.
As for the trans service, if you are correct, there have been some changes since I bought my 3xxx 2 yrs ago. First filter change @ 100 hrs and at ever 50 hrs afterwards. That doesn't make sense to me. Would also suggest you take a look in this forum for a very long discussion of the trans fluid. Several months back when I did my first trans service the dealer was wanting $13/qt for the fluid. Going by the manual this transaxle is spendy to maintain.
2014 Ford F-350 Western Mule 2,000 LB 1 Ton Crane Service Truck (A51692)
2014 Ford F-350...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
