Just Stopped while mowing
   / Just Stopped while mowing #1
stevemarion1010
seymour
Cub Cadet LTX1050
Just riding along mowing and the mower just died...put in new battery, spark plugs and air filter, still won't start. Can't find where the fuse is to change it...any help???
   / Just Stopped while mowing #2
It would help if you would post the Model Number. Cub makes or has made a lot of different mowers. I am sure someone on the Forum has the owners manual for your model giving the location of the fuse. Have you checked and made sure the plugs are receiving voltage from the coils? Did a safety switch malfunction and turn the mower off? Do you have compression? Remove spark plugs and crank engine while holding a finger over the spark plug hole, is the finger forced away?
   / Just Stopped while mowing #3
OP - look in the cavity under the tilting seat. Get the FULL model number and post back so we know what machine you have. Also pls clarify problem - you imply main fuse blown, but that you are cranking engine, but no re-start? That doesn't add up. Has tractor had any other recent history of problem/fixes?
2018 CHEVROLET SILVERADO TRUCK (A51243)
2018 CHEVROLET...
2012 JOHN DEERE 350G LC EXCAVATOR (A51242)
2012 JOHN DEERE...
2015 Dodge 5500 4X4 Bucket Truck (A52128)
2015 Dodge 5500...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
