• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users, including; Where to Buy, Future Retailers and Locations, Financing, Compatible Equipment, Tractor Operating, Equipment Specifications, Parts & Service Support, Warranty and anything else that may assist those in the market for a new tractor. If you cannot find the answer to a specific question on this forum, please feel free to contact Summit Tractors Directly or through a Private Message to Summit Tractors Support via TBN.
Ad top of page
Just purchased my Summit tractor and flashers and turn signals do not work
   / Just purchased my Summit tractor and flashers and turn signals do not work #1
Triple 5423
Summit TX25H
Just wondering if anyone here has had a problem with the flashers and turn signals, I am guessing it is a relay or a fuse I am just looking to see if anyone has had similar issues?
   / Just purchased my Summit tractor and flashers and turn signals do not work #3
If the tractor is new it is indeed a dealer problem. If you bought it used it gets more complicated. I'd start by replacing the flasher itself.
   / Just purchased my Summit tractor and flashers and turn signals do not work #4
I,m guessing it is a fuse. Do you have a test light, and know how to use it to check all the fuses ? A very quik and easy test, if you are familiar with using a test light. Also, make sure all the fuses are fitting snugly in their position. Sometimes, the female side loosens up enough to cause problems.
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
2009 Hartland Camper (A50514)
2009 Hartland...
Ad bottom of page
