Just purchased 2013 ds 4510
   / Just purchased 2013 ds 4510 #1
underdog01
helena mt
kioti
I've been reading on this site for quite a while now, learning all I can. I really appreciate this forum it has helped me a lot. I was going back and forth between a 50 horse TYM with hydro trans, a Kubota L3800, and the Kioti ds4110, and the ds4510hs.
As title states I settled on the ds 4510hs. Both the TYM and Kubota dealers were 90 miles away while the Kioti dealer was only 15 miles away. I would have bought the TYM if the guy would have tried to sell it a little bit harder. I understand most people don't like a pushy salesman. But I prefer to be sold. I'm not sure the Kubota was gonna cut it. I have 22 1/2 acres of rock. I have to build a road or two, retrench an irrigation ditch, and do alot of leveling and rock picking. The Kubota weighed 1000lbs. less, had 10 fewer horsepower, and the FEL was a 1000lbs weaker at break out force, and maximum lift. The Kubota also cost a few thousand more. I got the ds4510hs with a 6' box blade and a 6' rock rake and tooth bar for $22,000. It is my first tractor and I'm pretty excited, I can't wait to get out there and start moving dirt!
   / Just purchased 2013 ds 4510 #2
Congratulations and :welcome: , It sounds like you have your work cut out for you and the new Kioti. If you get time shoot us a few pics eh?
   / Just purchased 2013 ds 4510 #3
:welcome: My first tractor was a Kioti LK3054 nice tractor and did all that I asked of it. Sounds as if you have your work cut out for your self. Good luck!:thumbsup:
   / Just purchased 2013 ds 4510 #4
:welcome: To TBN and the Pack!
You will enjoy your DS4510. I have one and really like it. I traded in a DS3510 because
it did not have enough lift power. Now I have all I need. The KL402 is the same rating
as the KL401. Added extra remotes so I could do a hyd toplink and operate hydraulics
on an attachment behind like a disc with wheels...
ENJOY!
Tom
:thumbsup:
   / Just purchased 2013 ds 4510 #5
Congratulations. Great value for your money. My DS4510HS is up to 400hrs and it's met all my expectations.
Toro Zero Turn (A50324)
Toro Zero Turn...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Golf Cart (A51694)
Golf Cart (A51694)
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
