just learning to plow
   / just learning to plow #1
hughes
My boyfriend and I have taken it upon ourselves to plow 5 acres of our land in order to facilitate my horses living in their dream pasture at our home located in the beautiful and mountainous area known as the Kootenay region of British Columbia (located in the south east corner).
We have a couple of antique tractors, a disker, two mouldboard plows, a seeder and a lot of enthusiasm. Having said that its a bit like the blind leading the blind over here in Castlegar as although I have always had horses, I have usually boarded them out and although Dennis, my boyfriend, has many earthmoving machines (he is an industrial contractor) neither of us know much about tilling and planting with workable antique equipment and are basically just listening and learning to local old timers to learn about fertilizing and types of grass to plant.
Have said all that, what I would like is some good, clear instructions on how to use our moldboard plow. We've limed the sandy, acidic soil in the past couple of days, but when it came to hooking up the plow to our Dodge truck (having a wee problem with the picturesque tractor), we don't seem to be able to get the furrow thingys (sorry, don't know the terminology) to drop evenly into the ground. Of course, we've played with the two long handles that attach to the top of the plow, but there's some type of spring device attached one of the wheels that would allow both furrow things to drop evenly to plow the soil. Can you help us? Please!
Also, should we disk first, plow and then disk again? We want to plant clover and timothy grass before the end of September so it germinates before the snow flies and hopefully comes up again in the spring to give my horses a tasty pasture around May and help suppress the ragweed and dock that we spent 8 hours mowing last month.
I'd appreciate any information at all as we're flapping over here and getting a wee bit frustrated since time is of the essence.
   / just learning to plow #2
Welcome to the forum. Hopefully you will fill out your bio so we can have some info to go on.
You are asking for a lot. Are you serious about trying to pull a two bottom plow with a Dodge truck? Pics please.
From what you have posted, I would strongly suggest you find a neighbor to come over and plow your land. Then you might stand a chance of getting some seed in this fall. But it will not likely be in shape to pasture next spring, IMO. My experience shows that pasture takes awhile to establish.
If I am reading your 'plight' correctly, you have a lot to learn. I don't think I can be of much more help than to suggest you get some local instructions. If you are serious, then I would think the local people will help.
Maybe some others here can offer better help than I have. Trading some discussion with you may help a lot too. Don't give up on us too quickly.
GOOD LUCK TO YOU.
   / just learning to plow #3
Hi and welcome to TBN,
I live on the other side of the world so know little of your area. However i would not suggest using a moldboard plow for pasture, disks would be fine but be carfull not to plow to deep, with pasture i would only plow about 2"-3" deep. You will need some sort of harrows though to get the ground level after plowing.
Stay with us i am sure more advice will come
   / just learning to plow #4
Welcome to TBN.
From what you have said, you must have a pull type moldboard plow. I use a three point hitch type and have never used a pull type. I don't know if anyone here can tell you how to set it up or not. If no one speaks up, you might go to Yesterdays Tractors Implements and get one of the guys there to tell you how. I would imagine that the plow that you have is a very old plow and they would be able to help you.
   / just learning to plow #5
The plow set up.
If my memory is correct the right wheel of the plow sits in the furrow as do the right tractor tires. The swinging drawbar is pinned in place for this.
To keep shares level the right wheel has a lever that will adjust it's height. The other lever will set the depth to which you want to plough. The rear wheel should be adjustable for front back level but has no lever.
It will not plough properly till all the rust is off the mole boards.
Plough first and then disc lengthwise-crossways-at an angle to smooth things down. Probably get a rough ride for the first disking as the plough probably doesn't have the proper mole board for breaking sod.
Of course there is always a horse harness and walk behind single bottom plow with two handles you hang on to.
Good luck
Egon
   / just learning to plow #6
Is it a 3pt moldboard plow.. or pull type? Did you mean you have a 2 bottom moldboard plow.. or that you actually have two of them?
Some plows use shearbolts to prevent damage to the blade.. others have a re-setting device.. once the plow trips.. you back up and it resets.
I believe if you do a search on plowing.. several TBN'rs have discussed/explained how to plow.
There are two setups involved.. setting the plow up for the first two passes(all 4 wheels are on level ground) After that.. the plow has to be adjusted again.. because the right side wheels will ride in the trench from the first pass.
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A53843)
MCELROY 500 SERIES...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
1267 (A50490)
1267 (A50490)
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
