just got the 1547
   / just got the 1547 #1
donais
ramona ca
mf 1547
i have a retiring old mf40b skiploader that has the top and tilt that i installed, the new toy has the to slots on the right of the seat. does any one know how much those two cost? I would like three but want to keep it stock looking. unless the cost is like triple then i might go with gearmore or ???
   / just got the 1547
and a picture maybe
   / just got the 1547
or not
   / just got the 1547 #4
First Congratulations on the new tractor. The 1547 is a fantastic tractor. Did you get the open station or cab model?
The most that you can stack in the slots are two. You can add two more the way I understand it. I am at a little bit of a lose on the 1500, because I don't have a lot of paper work on them. I do know that one of the changes from the 1400 series to the 1500 series was the ability to add more factory valves. I haven't seen the price for the valves on the 1547, but on the 1440, two valves were in the $1000 range. If you want to go after market for your set-up I would suggest that you go with Carter & Carter. Mark Carter is a member here and has a great set up that many members have installed. BTW, Marks system is a lot less expensive than Gearmores.
   / just got the 1547 #5
Just a suggestion, even though you said you wanted to "keep it stock looking".
I had the dual remotes installed when I bought the 1455v new, and they suggested using a joystick to control them instead of the standard levers in the slots. May have been a price thing, I don't know. The joystick was mounted just behind the seat on the right side of the tractor, on the metal plate above the fuel tank and it's been perfect for me. Any time that I need to make an adjustment using the remotes I need to turn to the back to look anyway, so the joystick isn't hard to find or awkward. The best thing is that it's within easy reach to make adjustments from the ground behind the tractor when attaching implements. If I had the levers in the slots I'd have to walk around the rear wheel to reach the controls, and wouldn't be able to make adjustments as well. I don't remember about the 1500 series, as you might have some sort of hyd controls available from the back of the tractor? What seems to help me most is inching the tilt cylinder so things match up without needing a prybar or hammer.
   / just got the 1547
lucky for me im 6'4" so i got the reach thing covered. i will look at the carter valves. im having a hard time with the joystick my 40 b has a raise anda dump lever next to each other i love that setup, just gotta get used to it... and it is not a cab...san diego dont get cold heck we dont even get rain.. i am thinking about a canopy my neck got sun burned today...jon
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
Electric Concrete Mixer - (A51573)
Electric Concrete...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
