Just got my first tractor- Ford 1000
   / Just got my first tractor- Ford 1000 #1
GasNSteering
Zoo Jersey
Just picked up my first tractor, a Ford 1000 with a 770 loader. It has 1600 hours and is in real nice shape. It has the original paint, but some surface rust is showing thru. I will change all fluids, service and then begin the repainting process. Any thoughts and recommmendations would be welcomed. I have a few questions: Any place to get the decals? Does anyone have a manual for the loader? I am waiting for the owners manual..... is Rotella 15/40 a good oil for the engine? It does get to 0 degrees occasionally around here. What type of tranny/ hydraulic fluid will I need? Lift capacity for the loader? Thanks
   / Just got my first tractor- Ford 1000 #2
Welcome to TBN, someone should be able to help with your questions.
good luck..
TractorData.com - Ford 1000 tractor data .more than likely you already know about this site, but if not here it is.
   / Just got my first tractor- Ford 1000 #4
I will repeat the welcome.
I bought my 1700 new in '81 and have always considered it to be a quality machine, though now the years have necessitated some updates and repairs.
The lift capacity of my Bush Hogloader is 700#, yours is likely similar.
The diesel needs some cold weather considerations. I add about 15% kerosene when the temps are freezing or below - cheap insurance. If you run out of fuel, it is quite a task to get things bled out, but after a gel up - real torment!
I've found a block heater effective below 20 degrees, and try to park out of
the wind if not in a shelter.
The power service tip above is good. The new diesel fuels don't have the lubricity the old blends had. Dddaytives are now pretty much no question. They're all good, differences slight, but power service is available at "Wally World" at a reasonable price.
I have use Rotella oil, my last oil change was with Amsoil. Pricey, but, as the blond said, "I'm worth it."
Enjoy, be safe.
Bob
   / Just got my first tractor- Ford 1000 #5
If I remember right the 1300,1500,1700 shared the frame and thus lift capacity. The 1000,1100 and 1200's were less capacity.
Andy
Thanks for the advice so far. Any place I can get decals? Are there more active forums for these machines? Doesnt seem to be too much discussion about these machines.
   / Just got my first tractor- Ford 1000 #7
I never could find an immersion type engine block heater for my 1100. I used a return radiator hose heater with good effect. Jay
   / Just got my first tractor- Ford 1000 #8
My brother has a Ford 1000 that he is redoing. He went to a New Holland dealer and they were able to located all the decals. It took a lot of time and they were very pricy. He got his about 3 to 4 years ago. I have a Ford 1300 that I use for mowing and snowblowing. It is a smaller tractor then the 1000.
Ken
2013 FOREST RIVER CARGO TRAILER (A45333)
2013 FOREST RIVER...
Transmission-Allison 9823 (A45333)
Transmission-Alliso...
2001 P.J. MFG. CO. GOOSENECK TRAILER (A45333)
2001 P.J. MFG. CO...
2020 Takeuchi TL8 Skid Steer (A44391)
2020 Takeuchi TL8...
2012 Volvo EC250DL Excavator (A42203)
2012 Volvo EC250DL...
2007 BBB F40 STATION MANIFOLD TRAILER (A45333)
2007 BBB F40...
