Just Finished my 50hr. Service with Questions:
   / Just Finished my 50hr. Service with Questions: #1
DIYGuy
Central Massachusetts
Jinma 224
Let me get to the question 1st, and then my observations on my 50hr. self-service. AKA: Holy smokey, that's a really big mess.
My tachometer started failing intermittently about a month ago. It would sometimes register 1/2, or 1/4 of the actual speed. Sometimes it would register 0, and on rare occasions, it would register actual speed. Now it doesn't register anything at all for the last 8 hrs. or so of operation. I thought the error was a sensor adjustment.
I turned the sensor in 1/2 turn, still nothing. I rewired the connections as they were suspect, still nothing. I was leaning toward the sensor as I was getting some reading out of the tach, thinking that it wasn't sending all/enough pulses.
SO, I turned the sensor in a little further, and it made very light contact with the flywheel and I immediately backed it out.
I've probably damaged the sensor and will need a replacement even with the light contact. But then what? and how do I properly gap the sensor? And finally, this is the brass threaded thing about the size of a pinky finger, threaded into the bell housing right next to the fuel injector pump.
OK, Now onto the 50 hr. service.
I used all of the NAPA filters for my 224, Fuel, Oil, and Air. I removed all of the 4 major oil fluids first (Engine, Hydraulic, Drive line, and front diff.) There are more drain plugs on these things than I ever imagined. I now know that I didn't properly drain the rear differential or hydraulic reservoir when I assembled it. 4 plugs on the drive line, 1 on the front diff, and1 on the hydraulic reservoir.
The NAPA Oil and Fuel filters are substantially bigger than the Fram or Chinese units. The air filter is far more robust as well. NAPA filters from here on out for me.
The engine oil was filthy black. The hydraulic filter mechanism clogged with particulates. The front differential was in really good shape. The hydraulic oil was reasonable.
The other thing I've noticed is that there are several different takes on what to use for replacement oils. I forged a new path and made up my own list. It's like having your own religon almost.
Front Diff: 80w90 Hypoid Gear Oil (Almost 1 Gal)
Hydraulic Res. NAPA R&O Hydraulic Oil (15w I think) (2 Gal.)
Drive Line: 80w90 Hypoid Gear Oil (Little over 4 Gal.)
Engine: 15w40 (5qt.)
Fuel Injector Pump: 15w40 (~6 oz.)
These fluid amounts are the same as what I got out. I realize that 1/2 of the hydraulic fluid was not changed, probably left in the steering and pump.
Now the fun part. I had no idea how much fluid was in the drive line when I dropped the drain plug out of the rear diff and I mean dropped in the roll on the floor to a galaxy far far away kind of dropped. The creeper box, the gear box, the H/L box, the PTO mechanism, and the rear diff are all one big reservoir. So, I dropped the rear plug 1st, and I put my big 2 gallon oil pan underneath and went around the wheel (Galaxy Far Far Away) to pick up the plug, came back around and found 2.5 gallons of skany chinese oil in my 2 gallon pan, grabbed a one gallon pan, put it under, realized it was filling too fast.
Grabbed a 5 gallon pail (Tractor is up on ramps and jack stands to make working on the underside easier) and put it in the spreading puddle of oil to catch the last bits. I dumped my pan into the pail not knowing how much more there was and to start draining from the other plugs.
Lessons learned. A 5 gail pail is really hard to empty when it's full of smelly oil. The major service is hard work and you really need to time it so that you're not working in 20 degree weather. It needs to be done outside on a sunny warm day. A propane heater only goes so far and even running the tractor for 30 minutes to warm everything up only helps drain it out.
Another lesson, remove the towbar and it's support structure before draining out the hydraulic reservoir. What a mess that made. It dribbles out and runs down the back end where it then proceeds to coat the entire drawbar mechanism with 30wt. sludge.
How does it run now? Unbelievable difference. The drive line is much quieter. It starts much better (I wonder if the heavy fluid in the pump makes it tough to start?) I can turn the PTO shaft easily by hand, it was pretty stiff before. And the 3pt. works immediately after it starts. I didn't have to wait 10 minutes.
FWIW,
DIYGuy (MarkS)
Udate on Tach problem
Hi Gang,
I finally got sometime to work on my tachometer today and I must say I'm even more confused than ever. Ideas appreciated.
Previously, my tach was registering what seemed like random values. Recently it was not registering at all.
So today, armed with a multi-meter, I started to diagnose the problem. I disconnected it and measured resistance first. 1.04k Ohms across the leads. Don't know if this is good, bad, or indifferent.
Then I reconnected it, started the tractor up and verified it was still not registering. Then I placed the meter over the leads to determine what I was measuring for amps/volts. It took a little bit of work to get the meter onto the leads. The sensor initially measured 0.85 Vac. I looked at the tach and it was registering actual RPM. I don't know when it started working this time.
It measures 0.68-0.85 Vac regardless of engine speed, so I figured that the gauge was measuring ac amps. No measurable milliamps (perhaps my meter isn't sensitivie enough). I did this for 30 minutes.
I tested the meter on my working Oil Sensor and found 3.5 Vdc across the leads and 0.12 mV dc across the leads.
I tested all of the other electrical components on the tractor to make sure that they worked. The headlights are fine, rear lights, turn signals, brake lights, dash lights likewise.
Here's where it gets wierd. I hit the horn and the tach went to 0. Hit the horn again and the tach started bouncing back and forth from 0 to actual value and then settled down on actual value. Couldn't reproduce this effect at all and didn't get to measure the sensor. Total time for the wierdness was about 15 seconds.
I have no idea which way to go with this. Right now it's working just fine, but I have little confidence that it will stay this way.
I only care beacause of the hour meter and don't want to miss services.
DIYGuy
   / Just Finished my 50hr. Service with Questions: #3
Re: Udate on Tach problem
Though i have no idea why your tach isn't working, I would like to point out that you measure current inline in a circuit.. not across a component. And even the 9.99 auto store cheapy vom's should measure milliamps down to a very low scale.. just have to break the circuit though.
For what it's worth, did some design engineering for a water meter factory about 10-12 years ago, and they used a water meter that had a magnetic coupled drive, and it measured flow rate, plus flowed volume... Flow rate was a value based off of current flow, and displayed on a meter... so you may need to look into that further.
Soundguy
   / Just Finished my 50hr. Service with Questions: #4
I responded to your tach post on the CTOA site, so I won't repeat it here. But I will add that I have a new tach and sensor, if you get to the point where you think replacement.
//greg//
Thanks for everybody's help. This newbie is grateful for the education.
DIYGuy (MarkS)
Looks like a loose wire in the harness to the integrated instrument cluster. I pulled it all apart, fixed a couple of suspect connections, reassembled it, and no more flaky tach readings.
   / Just Finished my 50hr. Service with Questions: #7
Usually when a horn will cause electrical malfunctions it is a result of it "stealing" current from something else..... in your case, the tach. Bad connections are usually the culprit. I am not certain of the quality of the copper wiring that is used in China, so you might want to start there. It could be that the wire is causing a high resistance. We can discuss this further in two weeks........
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2023 Komatsu D61PXL-24 Crawler Dozer (A51573)
2023 Komatsu...
UNUSED AGT ATK-B1000 2 POST CAR LIFT (A51248)
UNUSED AGT...
ITEM LOCATION (A53084)
