Just filled tires with water
/ Just filled tires with water #1
Kfbeal
South Texas
2005 JD 5103
I've been meaning to do this for quite a while but just got around to it today. We don't have the winters many of you have, so if we get a freeze normally it's 60-70 later in the day or the day after.
We've always used water, so anyone questioning me I'll tell you my family farmed since the 1800's here and always used water. ;) If it's that cold for that many days I don't plan on being on an open-cab tractor.
Anyway, I used the adaptor purchased at Tractor Supply, not the one we typically used because I couldn't find it in the barn. It took approximately 20 minutes per tire. At times, I had to take the hose off to allow air to escape. It didn't seem like holding the air relief valve helped at all.
Maybe I did it wrong? I periodically pressed the relief, some water came out and then it quit. After removing the hose twice the water was at the top of the rim and I quit there.
I recall reading other threads about different or better adaptors and was thinking to myself had I know I was going to wait this long I would have ordered one and took this one back weeks ago.
My reason for filling the tires was for weight and pulling. I have a 14' disc I want to pull early spring and this little tractor was spinning with a 5' 3-point disc when set down deep.
/ Just filled tires with water #2
Well, it musta worked. :) I made a filler for the Kenbota rear tires. Just a simple filler. Add water, let air out, add more water, etc.
I haven't filled the big tractor tires yet. I'm still thinking (and saving) about getting all mine foam-filled. But I'll wait until the FEL is on to see how it handles. I need a few new tires first anyway.
Yea, it worked but seemed slow to me. If you need the adaptor I can mail it to ya so you don't have to buy one. I recall filling some 38's on the big tractors and it didn't see to take that long.
I've considered the foam, but not the expense. ;) Where I'm at we have quite a few thorns so flats are common, the main reason I didn't go with windshield washer fluid.
Which part are you located? In Wharton County here.
/ Just filled tires with water #4
Yeah, if it has stingers, thorns or fangs I have it! :D I'm in Atascosa County SW of San Antonio. Outside a little town called Lytle (Lye'-tul).
Don't really need a special tool but I appreciate the offer. I just used an air-inflater hooked to a hose fitting. Used water pressure to fill then just released air through the valve. It was a little slow since the valve stem passage is pretty small. I guess I could have pulled the valve and made the water fill faster but it was cheap. ;)
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2025 SDLANCH IREV Electric Scooter (A60352)
2025 SDLANCH IREV...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
