Just bought the Minot 20 hp
   / Just bought the Minot 20 hp #1
ZionHill
Lehigh Valley, PA
Minot 20 hp
Just bought the Minot (pronounced Jin-Ma) 20 hp from Tractor Supply Co.
It's a nice little unit. I'm not a heavy user so it should be fine for me.
I put a 3-point scraper blade on it to start because I need to do some grading.
I understand that the Koyker 140 FEL will bolt right on so I'll probably do that sometime before winter.
I'll be reading the posts to learn more.
   / Just bought the Minot 20 hp #3
Hi and welcome to TBN. What did you have to give for your Minot? I will disclose that I am a Farm Pro dealer and although TSC is not selling MINOTS in my area...yet... I just want to see what the market is doing. I would give hard consideration to putting a loader on that 2wd tractor, especially with Turf tires. certainly no bigger than a 4 ft bucket. you may want tire chains or a set of AG r-1 tires and rims for the back to make the tractor push the loader into your material. This tractor is great for finish mowing by the way. Have you contacted/visited your assigned "service center? thanks for any info you care to share.
Chip
   / Just bought the Minot 20 hp #4
Chip
   / Just bought the Minot 20 hp #5
</font><font color="blue" class="small">( I would give hard consideration to putting a loader on that 2wd tractor, especially with Turf tires. certainly no bigger than a 4 ft bucket. you may want tire chains or a set of AG r-1 tires and rims for the back to make the tractor push the loader into your material. )</font>
I'd never put a heavily loaded bucket over the OE turfs either. I'd be surprised if they had even 4 ply sidewalls. The turfs on my Yanmar were only 2-ply, and probably would have burst.
//greg//
   / Just bought the Minot 20 hp #6
//greg//
Hi,
Thanks for the advice about the tires. I'm a novice at anything bigger than a lawn tractor, and I've never had a diesel powered anything.
The price was $6,429 which I understand is what they are charging anywhere in the states. I'm in PA
Regards
Hi,
Regards
2008 Ford F-150 XL Pickup Truck (A53117)
2008 Ford F-150 XL...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
