Just bought a new Mahindra 3525
   / Just bought a new Mahindra 3525 #1
newtractor
Mississippi, Jackson county
Mahindra 3525
Hello everybody,
I'm new to the site and also to tractors. I just bought a new 3525 and so far enjoying it even though I've only put on it 4hrs. Do have a question that perhaps someone could answer, while pulling a 5' disc the tractor tends to bogg down when making turns and going up slight slopes is this normal? where should i have my thottle set and in what gear/hi/lo range should i be in? was in hi range 2/3 gear.
   / Just bought a new Mahindra 3525 #2
im new to tractors myself but i have been running a disc, i run at pto rpm, 3rd or 4th gear and i raise the disc before turning and let it back down when i get straight again. i havent had any trouble. does a 3525 have draft control?
   / Just bought a new Mahindra 3525 #3
You need to raise the disc during turns. Also, High range is probably a little too fast to be pulling the disc. I would drop into low range and try 3rd or 4th. Also, I had issues pulling a disc. Another member (don't remember or I would give full credit) mentioned that a front end loader on a tractor tends to "lever" weight off of the rear wheels thus affecting pulling power and causing more slippage. Anyway, I think slowing down would help you more than anything. We had some 100+ HP tractors over the years and if you pulled the disc as fast as they could you would dig a ditch. The disc would throw the dirt farther out than it could "cover" back up.
Yes the 3525 has draft control but i'm not sure if i understand how to properly use it. Also i used the tractor this evening and placed it in 3rd gear low range pulling a 5" box and it did a lot better. Like i said i'm new to tractors and with time i'll get better on thier use. Hey Hurd my tractor has the front Jerry can wt's could that effect the traction of the rear wheels?
   / Just bought a new Mahindra 3525 #5
Front jerry cans.... yeah I can see them having the same effect. Of course its a balancing act.. They are there to keep the front end on the ground. Pretty handy when using 3pt attachments.
Thanks Hudr, sorry for messing your name up on the last post. By the way that tractor sure does have some torque when used properly...i bent or better yet i twisted a scarfier and bent the side of my box blade. I got hung on top of a stump that i had originally ground down but now has been uncovered by my scraping /forums/images/graemlins/frown.gif. I might get this place in order if i can keep from going broke in repairs /forums/images/graemlins/mad.gif.
   / Just bought a new Mahindra 3525 #7
I also have a new 3525 with almost 24 hours on it. I pulled a 5 foot disc over about 10 acres with no problem. My tractor has the FEL and I pulled it in 1st gear of high range. But the other folks are correct about the turns. I would lift mine up when making turns. I ran over my place about 3 times with no problems. I did have an issue one time, but discovered I'd left my parking brake on. Happy discing. /forums/images/graemlins/smile.gif
   / Just bought a new Mahindra 3525 #8
Newtractor,
Congrats on your new machine. Those 3525's are really nice.
As others have stated:
*Lift the harrow before you turn. All of your runs should be in straight lines.
*Don't worry that your front weights are causing a problem. Actually, they will keep the front down as you lift the harrow to turn. They are not going to cause the rear of your tractor to loose traction. Just isn't possible.
* Do as you have said, and experiment with the gears in low range. Do not do any heavy work in high range. The heavier the work, the lower the range. However, you don't want to creep along the field like a turtle. If you are plowing about as fast as you could jog, then you are probably going fast enough. What you want to look at here is how the speed you are plowing affects the quality of the plowed ground. As you plow, the front disc's will throw the dirt out away from the center. Then the rear disc's grab it and toss it back in towards the center. Now, the plowed path should look smooth. If you see a center strip, like you are making a V, adjust your harrows by screwing the top hitch out. This will lower the read and and allow it to grab more dirt. If you are getting a hump in the middle of your plowed run, screw it in, because the back is biting too much. When you got your harrows, the were probably set so that the disc's are straight across both fron and back. This isn't going to accomplish much set in this manner. Both the front and back disc's should be adjustable. Adjust them so that if you were siting on the tractor looking at them in back of you, the front disc's are creating a slight V towards you and the rear away from you. (Front v, Rear ^ ) You wil want to play around with this setting until you get that smooth pass once they churned up the soil. Might be better to work on this in soft soil that will give you a more consistent pattern.
* You need to make sure your tires are filled with fuid. Up to the top of the rim, not over from what I understand. You can discuss this with your dealer or do it yourself. I've had some dealers put "some" water in the tires, but not near enough. If flooded properly, that tractor will be hard to stop.
* You will have to work your lift as you are working a free floating harrow. When you hit a very soft spot, the harrow will run very deep and this will bog any 35 hp tractor. I like to control the lift myself. You get a feel for it after awhile. Come up a little as you hit those soft sandy spots.
* You can't plow as deeply running up hill as you can down. And by this I mean even the slightest incline. Might not look like much of a hill, but your tractor knows the difference.
Take your time and be careful. Have fun.
Thank, HRS for the wealth of info! on the tire being filled with water is that something i need to do at all times or just for discing applications? Also i've noticed that on my tractor the 3pt lift dosn't have an immediate respond, in other words when i move the PC there is no movement till the very upper end of the PC lever travel is this normal? Anybody know if there is an adjustment that needs to be made?
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
1992 Peterbilt 377 Sleeper Cab (A52128)
1992 Peterbilt 377...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
