Just bought a JD 4320....advice?
   / Just bought a JD 4320....advice? #1
markmc
Hockley, Texas (outside Houston)
John Deere 4320
Hi Guys,
Long time lurker, first time caller. This is a great forum and I just wanted to introduce myself. I live in Houston Texas and have 13acres near Hocklet that I am going to build a house, barn, driveway etc on. I intend to use a cutter to clear a lot of the land and then regulary keep it mowed. I will also be moving dirt around, moving logs, digging up trees, buiulding my own driveway and probably the pad for the barn. I think I will hire someone to dig me a 1 acre lake and use the clay for the house pad with left overs for the barn pad.
I purchased the JD 4320 with the HST and a 400CX FEL. I didnt spring for the $5k - $6k cab+a/c but with the hot weather here in Texas I am beginning to wonder if I should have.
What do all of you think who are also in a warm area? Is it worth the extra money or should I just put money into more implements. Any and all replies would be appreciated. Thanks,
Mark
   / Just bought a JD 4320....advice? #3
Welcome to TBN. I have a 5105 which is exposed to the elements. Mowing all summer long the in heat is a pain but I also go onto unfamilar properties with lots of low hanging limbs and such so I do not think a cab would be good for my applications all the time. But I sure do wish I had one some times..Try looking into getting a canopy or umbrella. I just bought one about two months ago, I it makes all the difference to me - an umbrella that is. I can take it off easily to clear low limbs - much harder to do that with a canopy.
Thank you. I ordered it with a canopy. I was wondering what members thought about the health benefits of a cab. Would a sealed cab with a/c be any better than using a mask if you were prone to allergies from cutting grass?
   / Just bought a JD 4320....advice? #6
ABSOLUTELY...:D
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
John Deere 4020 Tractor (A50514)
John Deere 4020...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
