Just bought a chinese tractor. Did I buy a boat anchor?
   / Just bought a chinese tractor. Did I buy a boat anchor? #1
78sharpshooter
Yanmar 1300
Picked up a 1981 taishan 25 with disc harrow. Hasnt ran in quite a few years, turns over, 3 pt lift seems to work, came with 4 total wheel weights, looks to be of good build quality. Fuel valve seems to be gummed up. I cant see any info on the oil and fuel filters so if anyone knows part numbers or where to get these I would greatly appreciate it. Tried getting a hold of Chip at artrac and havent been successful the past few days. Is there a operation/maintenance manual available from members here? A few pics below- what is the cap with spring on the injection pump?{take a guess at how much I paid for this ;-))
   / Just bought a chinese tractor. Did I buy a boat anchor? #2
cap with spring looks like could be a fuel priming pump. need a better picture
Southern California
   / Just bought a chinese tractor. Did I buy a boat anchor? #4
Parts for that old tractor whether Japanese or Chinese are likely harder to find than hens teeth. Hopefully you can make it run without any new parts.
   / Just bought a chinese tractor. Did I buy a boat anchor? #5
I agree with feasant, that looks like a manual lift/priming pump used to fill(and purge air from) the filter and main injector pump body(should be a point to let air/fuel escape on top of IP and fuel filter). These diesels do not typically purge air from the hardlines and injectors very well so any air there will have to be released by opening the banjo fitting at the injectors WHILE cranking the engine. If you flush it out with fresh fuel and get all the air out of the IP and hardlines it hopefully will start when you crank it:)
How much did you pay? "Well if you can haul it away you can keep it"?
Well, knowing that parts would be extremely hard to obtain, I paid $150 but didn't know it came with a disc so I was pleasantly surprised
   / Just bought a chinese tractor. Did I buy a boat anchor? #7
Looks like an old Bosch design, that's the hand pump and it's probably mounted on the feed pump, the piston in the feed pump usually get stuck and the valves often must be cleaned.
This makes sense to me. I cannot seem to retract the knob or push it in much at all. so perhaps it is all gunked up. Thanks!
   / Just bought a chinese tractor. Did I buy a boat anchor? #9
There is more to a boat anchor than one might think.
Yes, the round knob is the manual lift pump. It is used for manually priming the primary fuel system. It utilizes the same spring loaded check valves as the lift pump. It is also sold separately from the fuel injection pump/governor assembly. No individual repair parts are available for either assembly. This is a cutaway view of your style pump assembly.
If you could furnish pictures of your fuel and oil filters along with part numbers that would help a lot. Also, you can take them to any GOOD auto parts store and they can match the dimensions as well as the thread pitch and size. There are also online cross reference tools by filter manufacturers.
Good luck, and have fun with your boat anchor.
   / Just bought a chinese tractor. Did I buy a boat anchor? #10
But you have loosened the hand pump by turning the knob?
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
