plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,394
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I was moving heavy items around the property today. Typical config-- two chains, each connected to a hook on the top side of the bucket. Wrap around my item, lift and go.
Got the last item moved, unwrapped the chains, and tossed them in the bucket. Was returning to base at moderate speed, but as I got closer I slowed down noticeably. That's the only thing that saved me-- the much slower speed. The hook at the end of the right side chain vibrated out of the bucket, and as it did some chain started to play out without me noticing. I couldn't see it at first since the bucket was in the way.
Faster than I could react, all the chain then came out with one exception. The other end was still attached to the bucket hook. It immediately straightened behind the bucket since I was still traveling forward and then it went under the right front wheel!!! Once it got pinned under the wheel, with me still traveling forward, it started pulling down on the bucket. A very uncomfortable thing to be watching. Fortunately, I had slowed way down, was paying attention, and immediately stopped when some force started to be applied to the bucket. I slowly backed up to release the tension on the chain. I looked things over and all seems well.
I don't know what would have happened if this happened 10 seconds earlier when I was moving at a much faster rate. But I don't think it would have been pretty. From now on, when I toss a chain back in a bucket, it will be unhooked from the grab hook on the bucket. I try to be careful but I had never anticipated something like this at all.
