Just another cab project
   / Just another cab project #1
jcurtisB78
Upstate NY
Kubota B7800
After several years of whining about having snow blow in my face while cleaning the driveway I made up my mind to get a cab for my B7800. It had been a while since I priced out all the options (hard doors, heat, etc.) so I had a bit of sticker shock when looking at what Sims and Curtis had to offer. What was about $3000 back in 2009/10 is well north of $5000 (Sims was over $6000). I also have a bud that has a soft-door Curtis that left me somewhat underwhelmed with regard to build quality, not really "bad" but IMHO not on par with the cost. Therefore, since I had build a few cool attachments in the past (wood splitter, backhoe, dumpcart, etc.) I decided to go the "build" route. After a few nights of internet surfing to find things like door handles, lights, and such I made some rough measurements and ordered the steel. I went with 1" square tubing for the framework, a combination of 1/8" X 1 1/2" flat bar and 14 ga strips for window bezels, and 16 ga for the roof. I decided to use 3/16 polycarbonate for the glass but I am not convinced that it was the best choice. It is as tough as nails but seems to scratch easy so time will tell if I went wrong. I also used Rustoleum rattle cans to paint it so I'll probably pull it off in the spring and give it a proper paint job. The project took the better part of two months from start to finish and I'm pretty happy with the results:
Photo Album
While I'm happy now that it is done, this project was one of the toughest I've ever tackled. The biggest problem was time crunch as I foolishly chose to start this project in the late fall and early snow interrupted the build. About half-way through I was convinced I would never finish and my wife is an absolute saint for putting up with me.
Part one of the three part mini-series:
   / Just another cab project #7
Very nice job. How did you bend the tubing?
There is a product called MR10, it's Lexan with a coating, the first time I saw it demonstrated they had a brillo pad under a windshield wiper, it had ran for days at the show and never scratched.
I used a tubing roller and dies from Harbor Freight:
Tubing Roller
3 Piece Die Set
This die set is for 1/2" tubing so I had a local shop cut them to 1". I bought an extra length of tubing just to practice but did not end up needing it as making the bends was not too difficult.
Thanks, I'll check it out, it sounds perfect.
   / Just another cab project #9
That came out great! What about mirrors on the side for backing up?
2002 CATERPILLAR 973C CRAWLER LOADER (A51242)
2002 CATERPILLAR...
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
