Just a Couple of Questions About Steiner/Ventrac and PT
   / Just a Couple of Questions About Steiner/Ventrac and PT #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
First, how come Steiner never got it's own section?
Second, I was reading a post about someone wondering if Steiner or Ventrak mower would fit a PT.
Is this to say that there three makes out there that use this same particular mounting system? I thought the PT had a boom and therefore driven attachments would need to be hydraulic.
   / Just a Couple of Questions About Steiner/Ventrac and PT #2
   / Just a Couple of Questions About Steiner/Ventrac and PT #3
Powertrac uses a hydraulic motor to run the deck……. jim
But they use the (same) Steiner lift arms?
   / Just a Couple of Questions About Steiner/Ventrac and PT #5
No, They don't……….. They have arms on the front like a loader, they can lift over 4' and they a quick coupler that locks with hydraulic cylinder. their system runs around 2500 lb. of pressure ………. Get on the PT site …….. jim
So why do I often see PT in the Steiner/Ventrac discusions as if all three are somehow in the same implement family or related in some way?
   / Just a Couple of Questions About Steiner/Ventrac and PT #7
They are all articulated, but as I understand them, that is where the similarity between the PowerTracs and the Steiners/Ventracs ends. Steiner and Ventracs are very similar to each other, as the Steiner family started Venture Products some years after selling the Steiner Tractor line to Textron, which in turn spun it off. Steiner tractors can use Ventrac attachments, and vice versa, with a belt or pulley change (or both). My understanding is that PowerTrac attachments are hydraulically driven, not belt-driven, so neither Steiner nor Ventrac attachments will work with PowerTracs.
   / Just a Couple of Questions About Steiner/Ventrac and PT #8
Powertrac has the engine in the rear ……… you don't look around a hood or add weight to the back to pick anything up. Great machine if they a weight transfer system on the 425, they did at one time that worked through the lift cylinders ……...
Hoemann Tire Balancer (A50121)
Hoemann Tire...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
2024 Victor X-PRO Mini Dirt Bike (A50324)
2024 Victor X-PRO...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
1993 John Deere 6400 (A50121)
1993 John Deere...
