Jump Start
   / Jump Start #1
Dougryan
Bronze Member
Webster, NY
Cub Cadet 3206
Hi,
I have an old MTD tractor that has been sitting for several years. I've almost trashed it a few times, but keep thinking that I could use it to pull my dethatcher or lawn trailer around... Anyway. I'm sure the battery is toast. It will crank a few times if I put my charger/starter on (55 amp boost). It's not enough power to really get it cranking.
So, without buying a new battery, what are my options? I can jump start it from my truck battery? With the truck running?
Thanks,
Doug
   / Jump Start #2
Hi,
Thanks,
Doug
You need a new battery. Once a SLA goes dead, it destroys itself. Sulfation creates impedance, so there is no high-current capability. That's why you can charge it, you'll get voltage, but you still can't turn over the starter. Sometimes you can recover the battery by charging to 2.5V/cell (~15V) for a couple of hours. After sitting around for a couple of years though - I'm betting it's toast.
Just to get it going, however, sure you can jump it. You don't need to start the truck (unless your truck's battery is dead too), just connect the truck battery and start the tractor.
JayC
   / Jump Start #3
I have one of those ctek chargers. Ive used it to recover a couple batteries.Canadian Tire
It wont recover all, but its worth a try. Plus it makes an excellent battery tender to keep your batteries healthy.
The best way to jump is to leave the battery in the circuit and touch the positive lead directly to the starter. You dont want to make a habit of jumping or you will burnout your starter with the high current from an automotive battery.
2020 McLanahan 150 TPH USP Sand Plant (A52377)
2020 McLanahan 150...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
