Jubilee turn distributor to start
   / Jubilee turn distributor to start #1
wnymudd
Bronze Member
Western New York State
2009 John Deere 3032e HST, 1953 Ford Jubilee, 1963 Fordson Super Major, John Deere 40, Huskee Lawn Tractor
I have a 53 golden jubilee that I have to turn the distributor to get it to start. I recently put a 6v electronic ignition in. Runs great once started. After shutdown, won't start warm or cold without advancing the distributor. Friend said I probably need to rebuild or replace the distributor shaft. Any thoughts? I have set flywheel 8 degrees btdc and rotor pointing at #1. I have set for 1243 firing order.
   / Jubilee turn distributor to start #2
Check to make sure the distributor advance weight's aren't seized up. Take the cap off and grab the rotor. You should be able to turn it and have it spring back to where it was an it's own
There's no springback just about a 1/4" of wiggle when moving the rotor. Where are these weights located?
   / Jubilee turn distributor to start #4
The weights are located under the the plate the the points are mounted on in the distributor.
I tried to look up Jubilee in the Ford parts diagrams online but obviously that 's a name for a tractor and not a model. Tractor Data does not list a Jubilee either.
Turns out I was missing the small metal clip that goes on the shaft. New Holland dealer had it and says that is what the problem is. I'll give it a try this afternoon.
It worked!
   / Jubilee turn distributor to start #9
wow.. i'm surprised it ran at all with no spring clip under the rotor! they usually backfire and pop and run like a bad advance.
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
Freightliner Tender Truck (A53473)
Freightliner...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
