Jubilee hydraulics
   / Jubilee hydraulics #1
dro
3 pt not lifting a heavy load. Loader will go up - slowly. Fluid up to line. Have bush hog on back and it just won't go up. Cold, it seems better but after running for awhile it will not rise. I have the shop manual but really don't understand it. Never worked with hydraulics and am a little nervous to "go in". Any suggestions?
Thanks,
Don
   / Jubilee hydraulics #2
prssure test it.
get a 0-3000 psi glycerin filled gauge that goes to pipe thread. put it in the port that has a pipe plug in it under the seat, or on the top of the pump head, or in the port with an inverted allen plug just above the relief valve on the lower part of the right side center section..
lift a load and look at the gauge.
also look in the hyd sump with a telescoping mirror and see if alot of oil is bypassing the piston and going out the mouth of the cyl.
post back
soundguy
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
Country Line Finishing Mower (A53117)
Country Line...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
