Joystick Options?
   / Joystick Options? #1
gekog
Oliver BC, Canada
1991 Case IH 535
Hi all. I am new to the site. I have a 1991 Case IH 535 with a Case 2255 Loader. I want to add a 4 in 1 to it. As far as I can determine, most 4 in 1's come with the bucket hydraulics, but you still need to add a 3rd valve and a 3-function joystick.
As I am new to this, I am wondering whether I need an open or closed valve?
Also want to be able to perform more than one function at a time like lift and tilt or lift and open the clam etc.
I have looked for joysticks, but really don't know where to find them or what type would be best. My present joystick is tower mounted and has a button on the top that leads to a wire that has been cut. I am wondering if that wire is for some kind of electric over hydraulic function?
Thanks from Geoff the newbie
   / Joystick Options? #2
Geoff,
I can't tell you whether you have a open or closed center hydraulic system. But I can tell you, one of the best places to get valves is a Burden's Surplus Center. Surplus Center valves
I would for sure trace down where those wires go. You may already have a diverter.
One more thing. Is your 535 a very large over 200 hp 4WD? or an Industrial? If it is an industrial, you might be able to get a good deal on a used 4-n-1 bucket if you look around a little.
   / Joystick Options? #3
I think what you are describing is electric over hydraulic. The specific examples you give can actually be done with a diverter though. What you need an electric over hydraulic system for is to tilt/curl at the same time as you open/close the bucket. Lift and open or lift and tilt can be done with a diverter valve.
Your current joystick could have been a diverter valve set up or possibly an electric over hydraulic. The diverters typically have a button on top while a common set up for the electric over hydraulic would be a toggle switch.
   / Joystick Options? #4
You should also check with WR Long, they probably have a electric diverter kit to add to you FEL to give you that 3rd function. You do not need to replace your existing joystick.
Also, do a search for these terms here on TBN, this very topic has been discussed extensively for those who add 4n1's and grapples:
wr long
grapple
4n1
diverter
Oh, and welcome to TBN:D
   / Joystick Options?
Thanks to all. I think I will go with the W.R.Long stuff. So far it looks as though to get the best versatility out of the loader, and 4n1, I should use an electric over hydraulic system and switch out my existing button for a toggle switch. I may already have a diverter valce though. I just don't know where to look for it. I also have 3 sets of remotes on the back.
The tractor is around 60hp - 53pto.
gk
   / Joystick Options? #6
gk
If I had a diverter valve I would give it a try before spending $800 or so on a electric over hydraulic set up. It is really not that inconvenient to temporarily lose the dump/curl while operating the open/close function. I've used both a diverter and rear remotes to control a grapple and find both perfectly adequate. No doubt the electric over hydraulic has advantages and is the best system but you might think of spending a week or so with the diverter set up before shelling out cash.
ABI TR3 LOT NUMBER 147 (A53084)
ABI TR3 LOT NUMBER...
Hyster H225E (A47384)
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
