Joystick in 5205 JD
   / Joystick in 5205 JD #1
Longr
2011 m9540 kubota
I have a 5205 with loader. The joystick control is not working properly. Took the plastic off that surrounds the joystick. Inside is a hard piece of plastic that keeps things aligned. There is a lock on the shifter such that when the lock lever is placed in the lock mode it pushes into the workings of the joystick and blocks it from working the loader. It appears that at some point the mechanism was in lock position and someone pushed hard enough to split the top and bottom of the plastic into two separate pieces. With this problem you have to use more pressure and find the spot that will cause the loader to perform what you are trying to accomplish. Has anyone out there had the same problem. Does anyone know where I can find the aftermarket replacement part. Hate to see what Ag-Pro is going to want for that part. Thanks for any help. rl
   / Joystick in 5205 JD #2
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2011 FORD F-450 (A52472)
2011 FORD F-450...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
