joystick control valve question
   / joystick control valve question #1
bazman82
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
Is swapping out a joystick loader control to a 3 lever loader control as simple as disconnecting the hoses and reconnecting the hoses in the proper spots??? For some reason, whenever I think out this I always think, there is a supply hose to the valve, then the different valves to the different functions, then a return hose to the tank. It sounds simple enough but I know its not and there is always more to it....
   / joystick control valve question #2
there's usually two "return" ports. A low pressure Tank port and a high pressure Power Beyond. PB goes on to feed the other valves, usually with the 3pt as the last in the chain.
There's a lot of different port connection types- JIC, SAE, BSP, etc. You will have to figure out what the current one has and either find a valve that's the same or buy adaptors.
Also the ports are not in standard locations so you may need longer hoses, different elbows on the end, etc.
2012 GREAT DANE 53FT REEFER TRAILER (A53426)
2012 GREAT DANE...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2017 TAKEUCHI TB290 EXCAVATOR (A51246)
2017 TAKEUCHI...
