Joined the Snowblower/Thrower crowd. Need Help!
/ Joined the Snowblower/Thrower crowd. Need Help! #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
I found a <font color="green"> John Deere </font> 46" Snow thrower for my F735 front mower.
I got everything needed to install it on my mower except the switch and wiring to run the electric chute rotation motor.
<font color="green"> JD </font> wants $50 for the wire harness that will hook to their toggle switch. I am sure I can make a harness for far less. I need of a double throw, double pole, monetary on in both directions, 20 amp. Toggle switch. Anyone know a good place on the Net or store that handles the switches at a lower price than <font color="green"> JDs </font> $23.
Thanks for any help.
/ Joined the Snowblower/Thrower crowd. Need Help! #2
Try Radio Shack. Suspect they have something.
Thanks I tired Radio Shack. Whenever I click on the site I get a MS error that shuts down IE. I will try again later.
Did check out Canada site it works. They have lots of switches. Found a couple that will work. Next weekend is Canadian Thanksgiving. I will be going there for Turkey. /forums/images/graemlins/grin.gif
/ Joined the Snowblower/Thrower crowd. Need Help! #4
Have you considered some of the marine supply stores? West Marine is one on the larger chains that is all around the country and on the net, too.
Some of their stuff is every bit as pricey as JD, but they have some reasonable stuff, also. Much of it (but not all) is intended for an exposed environment. A good thing for many tractors!
Peter
Southern Maine
Oliver 550
207270 (A52708)
207270 (A52708)
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
