Tiller john deere790 and yanmar 1500 tiller
   / john deere790 and yanmar 1500 tiller #1
j44nel
Anybody have any ideas if a 4 foot yanmar tiller (model 1500) will work with john deere 790? was told that it may contact the rear tires at times. was also told that with the four wheel drive that this would not be a problem.
thanks
   / john deere790 and yanmar 1500 tiller #2
If it is a cat 1 , it should not hit the rear tires. As far as size you should be fine, I have pulled a 60" with a 790 with no trouble at all.
   / john deere790 and yanmar 1500 tiller #3
I see in another reply that the yanmar is built in a way that it will probably hit your tires, so I have learned something new also. I use a japanese tiller that was sold with a Shibrarau tractor, it came out of the rice fields.
   / john deere790 and yanmar 1500 tiller #4
Go ask this over in the yanmar section. Yan mar tillers are not a standard 3pt hookup. the toplink area is different.. uses it's own bracket. From what i hear there is a conversion you can do to make them more standard.. etc.
Soundguy
   / john deere790 and yanmar 1500 tiller #5
I have a Yanmar 1303 tiller and use it behind my S650G. The tiller does sit tighter to the rear of the tractor (and therefore the rear tires) than my other implements, but as long as I keep my sway chains adjusted it does not hit. I don't know specifically whether the 790 would be similar and the various Yanmar models might vary in configuration. As far as I know, there is no need to use the special Yanmar toplink as they are actually made to work with the Yanmar tractors, not necessarily others. You will need a short toplink though. Probably in the 8"-12" long area. The pto shaft also usually needs shortened. I find the close fit an advantage for 2 reasons: 1) easier to maneuver in tight spots and 2) less lever arm on the tiller = fewer times the front wheels leave the ground.
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
